Old 05-05-2016, 10:35 AM   #1
captndan
captndan's Avatar
Default Rear end
Going to need a new rear end. Should I look for a complete used one, rebuild the old one, change gear ratios, look for someone to do it for me, leave it alone until it blows up? I am really not looking forward to this problem.
captndan is offline   Reply With Quote
Old 05-05-2016, 10:39 AM   #2
Mitch//pa
Default Re: Rear end
Curious to know what are your symptoms? Rebuild it with a different ratio would be my plan....putting in a used diff is a crap shoot at most with a lot of labor involved JMO..
Old 05-05-2016, 11:09 AM   #3
burner31
burner31's Avatar
If you are mechanically inclined I don't see why you can't do it yourself, changing the ratio is not that big of deal.
If you have the tools/desire/time...go for it.
If you want it fast, and have the cash, let a good, quality, and trusted shop do it for you.
Keith
Shawnee OK
'31 SW 160-B
Old 05-05-2016, 11:12 AM   #4
1930artdeco
1930artdeco's Avatar
Why do you want to change ratios? Just remember if you lower the ratio to much and you have a heavy car that will affect the performance of the car. But if it were me, I would rebuild before it blows on you.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-05-2016, 11:16 AM   #5
CarlG
CarlG's Avatar
Make sure you check out Tom Endy's tech article on rebuilding rear ends:
http://www.santaanitaas.org/technica...tech-articles/
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-05-2016, 11:53 AM   #6
racingrufus
racingrufus's Avatar
I used Tom Indy's article when I rebuilt my rear end in my 29 special coupe. I made the special tools he described and every thing worked great. Some one installed a 4-11 rear in my coupe in the past and I changed it to a 3-54 and I am very pleased with it. Dwayne
racingrufus is offline   Reply With Quote
Old 05-05-2016, 12:49 PM   #7
captndan
captndan's Avatar
That is a great tutorial. The only reason to change the ratio is because this will be a touring car. Now to find some help. Thanks
Old 05-05-2016, 03:18 PM   #8
JohnLaVoy
JohnLaVoy's Avatar
A rear end build isn't too difficult. Make sure everything is good a clean. New pieces like gears and bearings etc. always a good idea.
JohnLaVoy is offline   Reply With Quote
Old 05-05-2016, 04:21 PM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
What do you actually need? Do you need someone to do the machine work and then you reassemble, -or do you need it assembled too?? Come over to Elizabethton one day (about 45 miles to your east) and I will walk you thru what you need to do, then you can decide what is next for you.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-05-2016, 08:39 PM   #10
diomed
diomed's Avatar
I took mine apart, cleaned everything nice, then was immediately put on 60hr work weeks. After a few weeks of getting nothing done, I took it to a differential shop and had it all reassembled for $400. Totally worth it.
I installed 3.54 gears and I couldn't be happier. Lots of the boulevards here in town have 45-50mph speed limits and the car effortlessly stays with traffic.
kris
diomed is offline   Reply With Quote
Old 05-06-2016, 06:50 AM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
EVERYONE should have a 2 headed coin, to flip!
Bill Heads
"THE ASSISTANT GURU OF STUFF"
Old 05-06-2016, 08:12 AM   #12
larrys40
You are lucky to have Brent close to give good on hand advice. Rear axles are one of my specialties and can the common guy do it with a certain amount of common sense, the right tools, and reading up... some can... some can't! Depending on your own skill set, tools, etc you can make the decision to recruit help or do it yourself.
There's definitely a skill set, tool, and knowledge to doing them right.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 05-06-2016, 08:35 AM   #13
V4F
V4F's Avatar
ive done several with good results . it is mostly common sense with a good book
V4f
V4F is offline   Reply With Quote
Old 05-06-2016, 08:40 AM   #14
C26Pinelake
Once again Brent proves what a kind and generous person he is! We are indeed fortunate to still have him on the Barn! Wayne
C26Pinelake is offline   Reply With Quote
Old 05-06-2016, 08:50 AM   #15
captndan
captndan's Avatar
Great plan. I've been meaning to come over for a visit anyway. Hopefully I can drive the car over just waiting for the carb now. Thanks
