Old 05-03-2016, 04:09 PM   #1
carolinamudwalker
Default Radial tire pressure
What would be a good summer tire pressure for a light sport coup and new 19 inch radial tires? Bob
carolinamudwalker is offline   Reply With Quote
Old 05-03-2016, 04:26 PM   #2
CarlG
CarlG's Avatar
Default Re: Radial tire pressure
Coker sez:
Max Load Capacity (lbs.) @ (psi) 1235@44
Seems a little high, but ???
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-03-2016, 04:53 PM   #3
ian Simpson
Originally Posted by CarlG View Post
Coker sez:
1235 lbs is the max load on the tyre when it is inflated to 44 psi. I would start at 34 psi as per the Model A manual and go up or down from there depending how it drives.
ian Simpson is offline   Reply With Quote
Old 05-04-2016, 05:01 AM   #4
inex01
inex01's Avatar
I set my Slant Sedan at 36 LBS, tried 30, 32, 34 and then 36 which does feel like the ideal pressure because the car drives noticeably better at that pressure, My car weighs in at 2,550 LBS so the weight of the car should be considered, my suggestion is to experiment like I did.
Chuck McDonald,
Member of AACA, Model A Club, NRA
inex01 is offline   Reply With Quote
Old 05-04-2016, 05:18 AM   #5
Mitch//pa
What ever pressure you prefer use an accurate gauge... The old pop sickle sticks are not always accurate... Go digital (they are cheep) plus your modern iron will be happy
Old 05-04-2016, 09:33 AM   #6
jadatis
I am able to calculate it for you but need some data from you .
I assume the tire-data already given.
1235 lbs max cold pressure 44 psi but AT35 psi an american system Standard load P-tire the maximum load can be carried ( that 1235 lbs) up to 99m/h even, so will be high enaugh I think for this oldtimer
But look at sidewal for it , and see if you find something like reinforced/Extraload/XL, then its an XL// tire wich AT-pressure is 41psi in American system .
Then I need the weights on seperate tires best, second best axle weights , And the maximum speed you wont go over for even a minute in your use.
If you can collect these data , I can calculate a range in the pressure at wich no damage by overheating, and no discomfort by bouncing.
Greatings from a Dutch Pigheaded Selfdeclared tirepressure-Specialist.
Peter
jadatis is offline   Reply With Quote
Old 05-04-2016, 09:20 PM   #7
V4F
V4F's Avatar
I have a coupe . 16" radials . 33# front & 30# rear
V4f
V4F is offline   Reply With Quote
Old 05-04-2016, 09:27 PM   #8
SeaSlugs
SeaSlugs's Avatar
agreed i dont like those stick type at all, even the analog dial type can be off - ours is off 4lbs high (reads 4 high).
never ever inflate standard car tires to what it says on the tire - just asking for all sorts of trouble. Bicycles and lawnmowers are just about all you do that with.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-04-2016, 09:44 PM   #9
C26Pinelake
That is contrary to what the Goodyear guarantee states??? Wayne
C26Pinelake is offline   Reply With Quote
Old 05-05-2016, 10:22 AM   #10
katy
katy's Avatar
My old Schrader, from the '50s, still works excellent, check it every couple of years and it's bang on.
Old 05-05-2016, 07:24 PM   #11
eagle
eagle's Avatar
I run an extra 5+ # pressure in all tires, modern and A. They wear more evenly.
Old 05-05-2016, 09:20 PM   #12
SeaSlugs
SeaSlugs's Avatar
yea moderns i run about 40# when vehicle door says 32 - way too sqishy of a ride.
most manufactures recommended tire pressure is for the comfort of the ride VS tire life so what eagle says is true - does prolong the life of the tire.
Old 05-05-2016, 09:38 PM   #13
ian Simpson
Agreed. My Lotus ran on 17 front 35 rear!!!
