Go Back   The Ford Barn > The Swap Meet > Wanted > Model-A
Old 02-14-2016, 12:44 PM   #1
ldreeg
ldreeg's Avatar
Default Wanted Early 1930 Tudor parts for fine point
City: Dallas
State: TX
Original light rod switch 44 31/32"
Front crank pulley with integral washer
Oil fill cap 3/8" tabs 5/8" from top
Generator band 1 3/8" wide, no tabs J11 or J12 stamping
Starter band J11 or J12 stamping
Original Starter cable 19" length 9/16-19/32"
ground strap layered type 4 1/4" length
original battery hold down
Speedometer cable and housing for Northeast Oval Speedometer
ldreeg is offline   Reply With Quote
Old 02-18-2016, 09:14 AM   #2
ldreeg
ldreeg's Avatar
Default Re: Wanted Early 1930 Tudor parts for fine point
Also looking for original brake rods 5/16' diameter with rolled threads, head bolts with domed tops, condenser, front and rear shackles, original front yoke springs, tire pump hose, cowl kick panels, fan belt, radiator hoses and water pump.
Old 02-26-2016, 12:09 AM   #3
ldreeg
ldreeg's Avatar
btt
Old 03-03-2016, 11:42 PM   #4
ldreeg
ldreeg's Avatar
btt
Old 03-10-2016, 11:15 AM   #5
ldreeg
ldreeg's Avatar
Got the generator and starter bands from Generator Joe, Great to deal with.
Old 04-03-2016, 10:48 PM   #6
ldreeg
ldreeg's Avatar
Got brake rods, head studs and front shackles. Still looking for the rest. Thank you ford Barn!
Old 04-10-2016, 02:52 PM   #7
ldreeg
ldreeg's Avatar
Got the front pulley and oil cap. Still need the rest.
Old 05-03-2016, 09:39 PM   #8
ldreeg
ldreeg's Avatar
btt
