Old 11-23-2024, 10:48 AM   #1
old1957
Default '57 ford fairlane
I'm sharing this because others may have had this same problem.
I have a recently purchased a totally refurbished 1957 ford with 3-speed and overdrive that had a added power steering system. This type of power steering is the one where : Borgeson pump (pressure set at ford specs) connected to a "power control valve", and then to a "slave cylinder". When I got it it had a steering wheel shake (left to right). All air-in-the-system was eliminated. Pump press. set to ford spec (850 psi). New slave cylinder installed. 3-New "control valves" installed...same problem. The control valve from Lares, Summit, and other sellers for this vehicle was always the same control valve stating this was to work on a 1957 Ford Fairlane 500. Thanks for the diligence of my mechanic he obtained a "original" control valve that he took off from a 1957 Fairlane in a junk yard......and IT WORKED !! It looks somewhat different and the shaft/spools inside are different than the shaft/spools that every vendor is stating that fits the 1957 Ford I have. Problem is that it leaked (setting a long time) and needs new seals, but it worked perfectly !! To get me going he took the "control valve" off of his 1959 Ford Edsel.....and that works also. Why isn't the right part available from parts stores ? Good question....HUH !!![/B]
old1957 is offline   Reply With Quote
Old 11-23-2024, 11:07 AM   #2
KULTULZ
KULTULZ's Avatar
Cool Re: '57 ford fairlane
The valve you are describing is a CHI-CON OFF-SHORE ONE-FITS-ALL. It is junk.
That FORD valve has been out of production for how long, and that is the reason you cannot buy a new FORD part (other than maybe NOS or a good take-off). They can be professionally rebuilt/restored.
At least you had a mechanic who cared and took care of the problem.
Why the GM SAGINAW PUMP, an engine swap?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 11-23-2024, 04:11 PM   #3
Gene F
Gene F's Avatar
Default Re: '57 ford fairlane
If you could see what is in a rack-n-pinion ( i understand yours is slave) and see one getting rebuilt you would think twice about turning your good core in for todays junk. The hardest part is getting the screws out. Thinwall sockets, or screw driver bits, a 5lbs sledge, soaking the unit in PB Blaster for a week, a vice, a helper, and a good old fashioned impact driver.
NAPA used to sell rebuild kits.
My 57 does not have power steering, and unless I change it over to a 5-speed I have zero interest in power steering. I had a 1967 Mustang, and the power steering leaked no matter what I did to it.
Old 11-23-2024, 04:47 PM   #4
Ford Freak
Poor design. I could never get my '63 Galaxie to stop leaking. Same w/my brothers '64. Nature of the beast, I guess!
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 11-24-2024, 07:15 PM   #5
old1957
Thanks to all for the input about my '57 fairlane power steering problem. Yes, at least it's finally fixed.....and yes, thanks to the diligence of the mechanic I was working with. Next comment....Why would any vendor (and there are many of them) keep listing a part that DOES NOT WORK ! I am planning to give my feedback to many of these vendors. If they didn't know before, they will know that some "idiot consumer" let them know the valve they are selling for the application they are selling doesn't work !
Old 11-24-2024, 07:23 PM   #6
KULTULZ
KULTULZ's Avatar
Exclamation Re: '57 ford fairlane
Oh, that's any easy one.
They are there for profit only, they have no morals.
And then again, those that shop by price only, not considering quality.
You know, it some instances you have no other choice but to buy CHI-CON SLOPPY COPY PARTS, but the selling vendor should point out what it is they are selling.
And this is not only older vehicles but current also.
