Old 03-03-2016, 08:56 PM   #1
Scott H in Wheaton
Scott H in Wheaton's Avatar
Default hardware for '36 instruments
I got my 36 cab without instruments, so I don't have the hardware.
I checked Roy Nacewicz catalog and didn't see them.
My dash has goobered up studs (rust, dirt, primer, paint), and I think they might be 10-32
Does that sound right to hold in the speedometer and gauges?
Scott H in Wheaton is offline   Reply With Quote
Old 03-03-2016, 09:37 PM   #2
Bruce/CT
Default Re: hardware for '36 instruments
I'd call Roy and talk to him. If he doesn't sell them ( which I'd doubt) I bet that he could help you. I know this from experience
Good luck!
Bruce/CT
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford
Bruce/CT is offline   Reply With Quote
Old 03-03-2016, 09:41 PM   #3
jake197000
that sounds about right.clean a stud off and try one.
jake197000 is offline   Reply With Quote
Old 03-03-2016, 10:02 PM   #4
Scott H in Wheaton
so far in my hardware stash I haven't found a fine thread 10-32, only 10-24.
Maybe I'll grab a few at Ace Hardware and give them a try.
Old 03-03-2016, 11:13 PM   #5
SofaKing
SofaKing's Avatar
The studs on my 39pu for holding the speedo and cluster are 10-32.
SofaKing is offline   Reply With Quote
Old 03-04-2016, 09:10 AM   #6
TagMan
10-32 threads on the instrument studs for my '36 3w coupe, too.
TagMan is offline   Reply With Quote
Old 03-04-2016, 10:42 AM   #7
fordy_nine
I don't think there are any coarse (10-24, etc.) threads on anything Henry built during the early V-8 era, only fine and extra-fine threads.......Bob L
fordy_nine is offline   Reply With Quote
Old 03-04-2016, 10:49 AM   #8
flatheadfan
flatheadfan's Avatar
Try this: (epay) -
http://www.ebay.com/itm/10-STAINLESS...IAAOSwKIpV~esJ
flatheadfan is offline   Reply With Quote
Old 03-04-2016, 12:05 PM   #9
35fordtn
35fordtn's Avatar
Roy Does have them for sure
Old 03-04-2016, 07:47 PM   #10
Tom Smith
The instrument studs are for sure 10-32. Ace carries the hardware you need. I just did this work on a 36 1 1/2 ton truck. Had to repair for one stud that was broke off. Drilled and taped to use a screw instead.
Tom Smith is offline   Reply With Quote
Old 03-04-2016, 08:02 PM   #11
Scott H in Wheaton
I can't get a 10-32 to thread on, but I can get a 12-24 to go on.
I have 1 or 2 studs broke off, not sure, afraid to look up and behind to find out if its more than that!
Old 03-05-2016, 08:04 AM   #12
Scott H in Wheaton
The mountng studs are more like stubs. I think when the previous owner took out the instruments he took most of the threads too.
So you were abke to get a drill up behind the dash and drill out the broken one? Did you need to use a right angle adapter?
