Old 02-23-2016, 04:37 PM   #1
jsprengeler
Default Steering Box Rebuild
I swear someone posted this info here before.....anyone have a recommendation on a good place to send my 55 Ford steering box for a rebuild? Thanks!!
If you haven't screwed things up, you haven't done anything at all!
jsprengeler is offline   Reply With Quote
Old 02-23-2016, 05:30 PM   #2
zoegrant
zoegrant's Avatar
Default Re: Steering Box Rebuild
I used Lares corporation to rebuild the box in my 56 t-bird...www.larescorp.com 1-800-830-7161
zoegrant is offline   Reply With Quote
Old 02-24-2016, 09:29 AM   #3
Ole Don
Ole Don's Avatar
Lares is good people to deal with.
Ole Don is offline   Reply With Quote
Old 02-24-2016, 02:41 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
I send one to Lares years ago. The rebuild process may have been okay but after I had installed and filled the box with 90wt oil, I found that the box was leaking profusely from a crack at the base of the center tube where it meets with the lower bearing plate. I had to tear it all down again and weld that tube.
Be very careful not to bend this tube during removal or installation. Inspect that area carefully for cracking.
Old 02-25-2016, 09:08 AM   #5
jsprengeler
Thanks for the leads everyone!
