I have a rebuilt motor with pistons that come 0.20 over the top deck and a best gasket with a 0.42 compressed thickness will this work with a Winfield head with no relief cut over the pistons the rods will stretch at high rpm .
No you need 0.040- 0.050" clearance to be safe some get by with less but that is a risk
Certainly I wasn't prepared to take the risk in exactly the same situation and had the head machined using a computer program to provide clearance over the pistons
Keith |
tommy it wont work as colin said. I am doing this now same thing with red head .had .035 clearance could only advance 4 deg then pre ing. go ing to cut my head tom. for .050 clearance and try that also centrificul adv dist worked better than manuel advance I have fsi ign round off all sharp edges in comb .chambers
Cut down the piston tops.
I had the same problem with a Thomas Head. I had the head machined to provide clearance, same a "wensum" said.
Have you ever seen a Model A that would REV high enough to "stretch" the rods??---Sounds like one for "MYTH BUSTERS"!
Bill W.
yes I have I have a 2 port riley that I have had to 5500 repeatly
the head I have is aluminum so I took the head gasket and a scribe marked over pistons then took a sharpie then got my router and a carbide tip bit and removed the material and with a 90 degree die grinder polished with good results checking with feeler gauge and straight edge.
Outstanding. A man who wants to do something will find a way; a man who doesn't will find an excuse.
#12 | |
![]() Quote:
Good on you ![]() Having an alum super Winfield and having been in the exact same situation, I took PC/SR suggested action, i.e.- cut the piston tops off ....with a HAND SANDER ![]() |
#13 |
Do the rods really "stretch" that much and still return to their original length, or is it the crankshaft flexing at high RM? I vote for crankshaft flex.
#14 |
pistons stretch with heat iron stretches when heated don't know at what rate but I needs clearance regardless.
#15 |
I had a Model B cylinder head cut to raise the compression ratio by eliminating the reliefs in the head for the pistons plus some more material.
Using clay on the piston tops, I determined the overall clearance (including piston protrusion above the block deck and the gasket thickness) was 0.010". I ran the motor at a car speeds of 65 to 75 mph with stock differential gears, and initially the pistons did not come into contact with the cylinder head. However, once carbon built-up on the piston tops, there came a horrible knocking sound as the clearance between the head and pistons went to zero. That ended my experiment with a shaved cylinder head. The right way is to run a cylinder head with combustion chamber shapes designed for high compression. Reliefs in the head for piston clearance are a necessity.
Bob Bidonde |
#16 |
My Winfield crows foot aluminum head is still working fine with no relief cut into the head. I have a standard gasket, then a 0.031" copper spacer gasket and then another standard gasket. This was recommended by a shop that builds hi-performance and racing engines. The Ross pistons came up quite a way above the deck.
1965 Lotus Elan S2 1930 Model A Sport Coupe Last edited by bettlesr; 02-18-2016 at 09:53 AM. Reason: changed thickness |
#17 |
where did you get the spacer gasket I also have a Winfield red head that I will be putting on a motor that I plan to build in the future
#18 |
Innovative machine & supply makes head gasket shims.
http://innomach.com/ |
#19 |
tommy rand:
I bought my copper spacer from: Clark Copper Head Gasket 10510 Nassau Street Blaine, MN 55449 (763) 786-9590 I bought 2 pieces so I would have a spare. Thickness is .031" and is for .100" overbore. The part number for mine is PN030505-A Cost me $65 each in 2011 Good Luck Dick
1965 Lotus Elan S2 1930 Model A Sport Coupe |
#20 | |
![]() Quote:
