Old 01-26-2016, 04:44 PM   #1
xmarine
xmarine's Avatar
Default Stumped on light rod
Attachment 255785 I have a 30-31 steering box with a repop 28-29steering wheel with the single keyway.When I try to install the 28-29 light rod it will not seat down on the wheel like it should.At this time I am not worried about the rod length.Just what to know why it is not fitting correctly.Any ideas?
Attachment 255786
Attachment 255787
Attachment 255788
Attachment 255789
xmarine is offline   Reply With Quote
Old 01-26-2016, 04:56 PM   #2
2manycars
2manycars's Avatar
Default Re: Stumped on light rod
You need the 28-29 style rod on the early style wheel. It is cup shaped to clear the wheel nut. On the later wheels, the nut is recessed, and that is why the rod you have is flat on the underside.
2manycars is offline   Reply With Quote
Old 01-26-2016, 07:07 PM   #3
xmarine
xmarine's Avatar
Is'nt this a 28-29 light rod?
Old 01-26-2016, 07:58 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
No, the 29 horn button is bright metal (nickel plate).
Old 01-26-2016, 07:59 PM   #5
Bob C
The one you show is a 30-31.
Bob
Old 01-27-2016, 12:11 AM   #6
Bader
Bader's Avatar
Like this one.
Bader is offline   Reply With Quote
Old 01-28-2016, 06:27 PM   #7
xmarine
xmarine's Avatar
Once again the fordbarn has come thru.The previous owner of my basket case 1928 ccpu had bought a 30 steering box,a 28 keyway steering wheel, but didn't buy a 28 light rod to fit the new steering wheel.Had me stumped till you guys straighten me out.Thanks again
Old 01-28-2016, 08:27 PM   #8
jm29henry
jm29henry's Avatar
I believe that your rod is to long if you measure from the back side of the switch to where the retainer clip goes I would guess that it measure 45&3/4" you need a rod that measures 45" even again from the back side of the light switch to where the grove for the retainer clip please let us know how this works out.
jm29henry is offline   Reply With Quote
Old 01-29-2016, 06:49 PM   #9
jm29henry
jm29henry's Avatar
X marine do you have an update?
Old 01-29-2016, 10:48 PM   #10
xmarine
xmarine's Avatar
it's fixed.The barners were right.Changed to a 30 steering wheel,with that light rod shown and all went together
