Old 01-21-2016, 12:09 PM   #1
SHEC
SHEC's Avatar
Default Correct location of tire logo on a 30-31 19" Rim
For "standards"
Does the Firestone (or other manufacture logo), go above the valve stem or - the "Gum Dipped" signature go there.
Ready to mount up 5 new Firestones on my touring car and would like your input -
Thanks -
Chris -
SHEC
SHEC is offline   Reply With Quote
Old 01-21-2016, 12:16 PM   #2
31Tudor
31Tudor's Avatar
Default Re: Correct location of tire logo on a 30-31 19" Rim
It is not specified, but the conscious effort is to center the Firestone on the valve stem.
31Tudor is offline   Reply With Quote
Old 01-21-2016, 12:31 PM   #3
Tiny
Tiny's Avatar
Tire logo should be centered on the valve stem. That way you can read it on the spare out back. I had a shop redo my tires after I taught them this lesson. A little attention to details goes a long way.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 01-21-2016, 12:53 PM   #4
J Franklin
J Franklin's Avatar
I doubt the cars came from the factory with the tire logo in any specified location.
Old 01-21-2016, 01:10 PM   #5
Jim Brierley
I agree with J Franklin. Most tires have a small dot indicating the light spot and that is to be mounted at the stem area.
Old 01-21-2016, 01:31 PM   #6
DougVieyra
DougVieyra's Avatar
My understanding is the same as Jim's. The lightest part of the tire was marked with a red dot, or square, etc. The weight of the metal valve stem of the inner-tube would by aligned with the tire's red dot, and they should be mounted as such. The tire makers name was not a relevant issue, and could wind up anywhere on the wheel.
DougVieyra is offline   Reply With Quote
Old 01-21-2016, 01:47 PM   #7
31Tudor
31Tudor's Avatar
The "Science" aside, I have mounted tires on rims where I didn't pay attention to logos or dots and I have mounted tires with the attention of detail to line the logo up with the valve stem; I have not had any difference in the way the tire ran, tracked, bounced or wore. Nor have I ever balanced a tire. Obviously is doesn't matter to some people where the logo is, but if you do make a conscious effort it is hard not to line the logo up. It has a nice finished look (to some) to have the tire manufacturer , the valve stem and then the Ford on the hub cap perpendicular to the valve stem (which is specified in the Restoration Guidelines.) So, end of the day, it probably really is just a personal decision.
Old 01-21-2016, 02:07 PM   #8
C26Pinelake
Where did you learn this lesson? I have never ever seen it in print! I am told it is an opinion only and not prescribed anywhere. Unless it is in the judging stAndards an opinion means nothing! Wayne
C26Pinelake is offline   Reply With Quote
Old 01-21-2016, 02:14 PM   #9
Mitch//pa
For judging purposes my Goodyear logo is centered to the valve stem. Then the hubcap upright to that.. As tiny said the spare will have the logo straight up, the stem pointing down and the hub cap readable straight accross.
Don't worry about the dot it doesn't effect crap...
Now talking modern::
We do a large volume of tires no matter where the dot is inside/ outside etc etc the tires take the same amount of weights. Many tires are directional where there is no choice but to put the dot on the inside...
Old 01-21-2016, 03:38 PM   #10
reggiedog
reggiedog's Avatar
I didn't know that these tires could be ballanced as I have always been told ????.
I can't get them balanced anywhere around me where can I have this done is there a certain company that does just this???
Thanks let me know Reggie
reggiedog is offline   Reply With Quote
Old 01-21-2016, 05:00 PM   #11
Cape Codder
Cape Codder's Avatar
I have installed new tires on newly powder coated rims a couple of years ago. I installed the stems, logos, and hub caps according to the judging standards.
[B]reggiedog[B]- I also installed pellets inside of the tubes for balancing of the tires. I only have about 3,000 miles on the tires, but there has been no wear and car drives nicely.
Cape Codder is offline   Reply With Quote
Old 01-21-2016, 06:32 PM   #12
jw hash
jw hash's Avatar
it used to be in the standards about the good Year boot lining up with the valve stem that was done away with in 2011. now it says the balancing mark is in adjacent to the valve stem.
jw hash is online now   Reply With Quote
Old 01-21-2016, 06:43 PM   #13
C26Pinelake
There is your answer. Good Book says balance mark adjacent to valve stem so any other opinions don't matter. Wayne
Old 01-21-2016, 07:07 PM   #14
reggiedog
reggiedog's Avatar
How can you get the pellets inside the tubes and what type pellets are they ????.
Old 01-21-2016, 07:12 PM   #15
Mitch//pa
Do a google search for "dyna beads"
Old 01-21-2016, 08:11 PM   #16
C26Pinelake
A good project to get the grandkids involved in and if works. Wayne
Old 01-21-2016, 08:51 PM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
One smart ass told my spare valve stem was pointing the WRONG WAY!---"Take a CLOSE look at it"----------"I LIKE IT THAT WAY"!!!!!!!!!!!!!!!!!!!! He didn't even own a Model A, or a DOG, but had a BITCHY WIFE!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-21-2016, 09:25 PM   #18
RonC
RonC's Avatar
I don't think any tires made today have dots that indicate balance points. The Goodyear tires made today have dots but are not balancing dots according to Kelsey tire who makes them.
RonC is offline   Reply With Quote
Old 01-21-2016, 09:33 PM   #19
C26Pinelake
Bill W.
The self professed experts are the worst kind ! Hopefully the wife gave him a razzing for making a fool of himself! Wayne
Old 01-22-2016, 12:00 AM   #20
Henry's Lady's Man
Henry's Lady's Man's Avatar
Wow, Mitch... I just read the link on DynaBeads. They sound great, if you need them. It looks like they are actually put IN THE TUBE, removing the valve core, and ALSO put (preferably) OUTSIDE THE TUBE before mounting the second tire bead. Is this correct? Have you used them? Or seen results?
... prosperity is not the product of charity but of industry - HENRY FORD
Henry's Lady's Man is offline   Reply With Quote
