Old 01-23-2016, 11:57 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Rear flywheel to motor mount bolt question
Do the bolts used to secure the rear motor mounts to the flywheel housing use lock washers and security wire, or are the bolts wired in together alone??
Thanks!!
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 01-24-2016, 12:24 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Rear flywheel to motor mount bolt question
Use lock washers and wire.
Old 01-24-2016, 08:01 AM   #3
Patrick L.
Patrick L.'s Avatar
I just clean, lock-tite, install, torque and lace them.
I'm thinking the last time I had this monster apart I may have used flat washers. It was more than an hour ago so I don't recall. I'll let you know if/when I ever take it back apart.
Old 01-24-2016, 09:51 AM   #4
Steve Plucker
To have the correct assembly...Tom is correct.
Pluck
Old 01-24-2016, 11:13 AM   #5
Jerry in Shasta
Jerry in Shasta's Avatar
let's see now, lock washer, safety wire and lock-tite. That's like wearing suspenders, and a belt on bib overalls.
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 01-24-2016, 01:11 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Posts #3 & 5 are REALLY FUNNIE!!!--LOL---
Bill W.
"THE ASSISTANT GURU OF STUFF"
