Old 01-08-2016, 12:31 AM   #1
harleynut
harleynut's Avatar
Default steering box oil
Old subject I know......just looked thru the search section and couldn't find a previous thread about steering box oil. I just rebuilt my 2 tooth and if I'm not mistaken I read some guys were using STP. I think it calls for 600W which really isn't 600W according to the label on the bottle from Snyders. It's comparable to 250W modern oil. Mikes Affordable has true 600W but is very pricy plus shipping. Hope I did the right thing. Book calls for 4 1/2oz I mixed 2oz STP with 2 1/2oz 600W which is really 250W. Am I being to pickey here?
i
harleynut is offline   Reply With Quote
Old 01-08-2016, 12:50 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: steering box oil
Yes!
Let me help those reading this that don't know.
600W is a trademark name. It is NOT 600 Weight. Just like Big Mac is a name of a burger and not some big guy named Mac.
The company that made 600W was bought out many years ago by Mobil. Mobile still makes the oil today, and yes you can still buy it. (We use it at work for worm gear gear boxes).
The ISO Viscosity Grade is about 340 and the ISO gear oil grade is about 140. Viscosity charts
Old 01-08-2016, 01:28 AM   #3
SeaSlugs
SeaSlugs's Avatar
id say your 50/50 of oil to stp is just fine. Worst thing you could do is have it dry in there so just watch for puddles or leaks and keep it filled.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-08-2016, 08:19 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Whatever liquid you use in the steering gear box, it will wind up on your garage floor no matter how well the gear box is sealed.
I find that synthetic grease works well, and it doesn't leak. To add grease, replace the fill plug with a grease fitting and pump the gear box full.
Once the gear box is full of grease, it will act as seal so you can add a little amount of synthetic oil.
The principle property of a steering gear lubricant beside lubricity is resistance to squeeze out between the gears.
Bob Bidonde
Old 01-08-2016, 08:20 AM   #5
Lona
Lona's Avatar
I had a steering box leak too. Used 90 wt which leaked worse. Also used 600W which was better but still leaked. Per suggestions by others on the forum, I used Penrite steering box oil from Restoration Supply in Escondido, Ca. over a year ago and it stopped the leak completely.
Glen
'31 Model A Deluxe Roadster
'35 Packard Convertible Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 01-08-2016, 08:29 AM   #6
zzlegend
zzlegend's Avatar
Originally Posted by lona View Post
i had a steering box leak too. Used 90 wt which leaked worse. Also used 600w which was better but still leaked. Per suggestions by others on the forum, i used penrite steering box oil from restoration supply in escondido, ca. Over a year ago and it stopped the leak completely.
Glen
x2
zzlegend is offline   Reply With Quote
Old 01-08-2016, 09:31 AM   #7
Terry, NJ
Terry, NJ's Avatar
I like STP! In small amounts. I believe that many original Fords would be running today if it was around in the 1930s. But that's not what this thread is about! Probably every oil and grease combination has been tried in varying proportions. JD Cornhead grease is one that intrigued me. Lucas Hub oil is thick, especially when cold, but it leaks out slowly. It's great for shifting in the transmission, in warm climates! Some people run their cars on straight STP in everything but the engine. For something that says it's not a lubricant, it lubricates awfully well. Then there's 90 wgt gear oil or GL1. But we keep coming back to what Henry Ford speced in 1928, 600 oil. It works and has no major drawbacks!
Terry
Old 01-08-2016, 09:48 AM   #8
JOHN CT
JOHN CT's Avatar
Originally Posted by 1930 coupe View Post
The pictures show a leak location that many people overlook. The scribe marker shows the maximum oil level before it leaks out of the slot. You can be careful and not overfill it, or you can fill the slot with sealer.
Go point I never knew that. So what should be the proper oil level ? I had my steering box rebuild a few yeas ago and it leeks since rebuild. I was thinking about pulling it back out, but now you have me checking into it further thanks !
JOHN CT is offline   Reply With Quote
Old 01-08-2016, 10:02 AM   #9
Bob-A
Bob-A's Avatar
Thumbs up Re: steering box oil
Like Lona & zzlegend, use Penrite steering box lube and there will be no leaks!
Bob-A
Bob-A is offline   Reply With Quote
Old 01-08-2016, 11:33 AM   #10
HoarseWhisperer
HoarseWhisperer's Avatar
Been using Penrite steering box lube for 7 years now. Stopped a leak that I was certain required a rebuild. Good product!
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 01-08-2016, 11:45 AM   #11
Ron Lachniet
Ron Lachniet's Avatar
I mixed John Deere corn head grease and regular gear oil about 50/50 and it works very well. It stays fluid but it clings to the gears and doesn't leak.
Ron Lachniet is offline   Reply With Quote
Old 01-08-2016, 01:45 PM   #12
harleynut
harleynut's Avatar
Wish I would have known about the Penrite product before I added the oil. I did use the end plate with the long tube on it from Snyders (A-3568) that should help which keeps the oil level below the end of the tube. I hope
Old 01-08-2016, 03:28 PM   #13
Pete
It didn't leak from the factory.
If it leaks, you didn't do something right.
If it's right, it won't leak even with carbon tet (Ccl4) in it.
Old 01-08-2016, 04:21 PM   #14
hangarb7
yep, everyone has an opinion. After seeing the suggestion for John Deer Cornhead grease, buying and experimenting with it just to see how it works (liquid when in motion, soft grease when not in motion), and adding it to my gearbox, no leaks and I am well pleased. About $5 for the tube at any JD dealer.
JackD
hangarb7 is offline   Reply With Quote
Old 01-08-2016, 05:37 PM   #15
Manager
Manager's Avatar
Smile Re: steering box oil
I found this out by accident. My box has grease in it from the previous owner. The steering seemed to have got a little stiff so I added some penrite transoil (which I use in the transmission) and it's fine and doesn't leak. I had to make a bit of a path with a bit of thick wire through the grease around the inside of the fill plug.
Manager is offline   Reply With Quote
Old 01-08-2016, 07:53 PM   #16
Mitch//pa
Just keep topping it off periodically it will take more....
Old 01-08-2016, 09:16 PM   #17
G&N Farms
G&N Farms's Avatar
I have a leaking steering gear box. I filled it with STP and it leaked out over time, on the floor, it's real sticky, on the floor..
I'm getting ready to rebuild the box and wondered where to get the Penrite ?
G&N Farms is offline   Reply With Quote
Old 01-08-2016, 09:44 PM   #18
Fred S
Fred S's Avatar
Restoration Supply
restorationstuff.com
Fred S is offline   Reply With Quote
Old 01-08-2016, 09:45 PM   #19
Bob C
See post #5.
Bob
Old 01-08-2016, 10:00 PM   #20
dalton
Glen
http://restorationstuff.com/index.html
dalton is offline   Reply With Quote
