Old 01-08-2016, 04:19 PM   #1
Larry Jenkins
Default 1930 under tank gas valve
Some time ago, I replaced the gas valve packing. At the time, it seemed a little long because the screw cap didn't go down very far at all.
Later, I couldn't turn the valve handle. Seems like the stem was froze up due to the packing being too large. All suppositions on my part.
Finally got the stem to turn. Pried the stem and packing out and cleaned well.
Now thinking about using an "O" ring. Initial indications are that a 3/8" I.D. x 5/8" O.D. would work.
Anyone done this? What size did you use? Thank you!
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 01-08-2016, 06:09 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 1930 under tank gas valve
I used the original packing after I lapped the taper with toothpaste. I greased the taper and packing as I assembled it, and it's been working perfectly for 20 years now.
Old 01-08-2016, 06:20 PM   #3
d.
what Tom said...the toothpaste lapping of the taper really works well to burnish the 2 surfaces to allow a good seal. I never tried the greasing of the taper before reassembly, but it makes sense and obviously works...Toms 20 year trial test proves that.
d. is offline   Reply With Quote
Old 01-08-2016, 06:27 PM   #4
Rowdy
Some of the packings (Macs) I have seen are too thick. Possibly order the proper thickness packings from Berts. I have replaced a couple of packings with the ones bought from Berts and no problems. Have about 15 of these valves on the shelf. May lap some of these and put in new packings to sell this spring. Healing up right now, so can not go dig to get an exact count. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 01-08-2016, 10:30 PM   #5
dalton
I got my 28/29 valve rebuild kit fom Snyders. lapped it with valve compound and its working great. I have only soaked the tank with Evaporust, so I can't say with gas, but I'm hopeful.
dalton is offline   Reply With Quote
Old 01-09-2016, 12:47 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
If you use toothpaste use the white kind not the gel kind.
Old 01-09-2016, 05:35 AM   #7
Steve Plucker
I like Crest myself.
Pluck
Old 01-09-2016, 09:21 AM   #8
Larry Jenkins
Pluck
Tapered part of the stem and the valve inner body have a nice, smooth finish. Now, how about the "O" ring idea?
Old 01-09-2016, 07:55 PM   #9
duke36
This may be off topic as not stock looking, but after having many A's and leaking valves, one option was to replace the valve completely. Remove valve from tank bottom, install an elbow in the tank opening (available from most hardware stores), take a stock A gas line with brass end fittings and cut a section out and install compression fittings with a modern 1/8' ball valve.
Old 01-09-2016, 09:23 PM   #10
DougVieyra
DougVieyra's Avatar
Rip - while doing what you suggest IS quite efficient and 'leak-free', it does look quite a bit 'out of place'. I used a variant of that system (the famous 'Dog Leg') for about six months, while cleaning out all the debris and rust in my gas tank. It worked well, but did look like it belonged in a basement boiler, rather than on a car (of any marque).
So after it did it's job, I took it off, set it aside for future use, and replaced the original stock (rebuilt, from Bert's) tank fuel shut-off valve.
DougVieyra is offline   Reply With Quote
Old 01-09-2016, 10:14 PM   #11
Larry Jenkins
Has ANYONE tried the "O" ring replacement?
Old 01-10-2016, 01:15 AM   #12
DougVieyra
DougVieyra's Avatar
Larry Jenkins - "Has ANYONE tried the "O" ring replacement?
______________________________________________
Well, Larry, you pointedly asked the question THREE TIMES - yet still no answer, or even a reference to the 'O' ring question.
Which would seem to reflect poorly on our ability to focus on the question. So at least from those who responded with a post, a 'no answer', it would appear, is a "No" answer. No one has tried using an 'O' ring.
It appears that you must indulge the FORUM readers a bit longer, in the hopes that later on down the road, someone will find you thread, and reply with a positive answer and give their results.
Sorry that we have only 'danced around' the question and not been able to give a more positive answer to your question. But don't give up on the FORUM, I am sure SOMEONE has tried the 'O' ring, and will eventually find your thread, and give a response.
Old 01-10-2016, 03:29 AM   #13
tbirdtbird
none yet
'31 180A
tbirdtbird is offline   Reply With Quote
Old 01-10-2016, 04:00 AM   #14
Mike V. Florida
As for the O ring, we purchase the rebuild kits from the vendors because "Good enough.. isn't".
Old 01-10-2016, 07:27 AM   #15
C26Pinelake
For less than a dollar you can try your O ring! Currently it would appear that people for some reason have not tried it. So this is your opportunity to be a pioneer! Wayne
C26Pinelake is offline   Reply With Quote
Old 01-10-2016, 07:53 AM   #16
Pete / MA
Pete / MA's Avatar
http://www.elastotechgaskets.com/sta...namic_seal.php
An old millwright told me o-rings were best for static or non moving sealing and self lubricating packing or lip seals, were best for dynamic (moving) sealing jobs.
To answer your question, no, I have never tried an o-ring on my fuel valve. I have used the kit that Snyder's sells a couple of times with good results...........Pete
Pete / MA is offline   Reply With Quote
Old 01-10-2016, 08:49 AM   #17
kenparker
kenparker's Avatar
Ok,OK,OK, but don't yell at me.
I have used the O ring on several occasions and currently run one in both my 28 Pickup an 31 Coupe. But, as stated above the O ring is for static applications and NOT for moving joints as is the Shut Off Valve. I do not turn my gas valve off each time I park my A's, not even at night. I instead rely on the electric shut off valve installed in the fuel line.
The O ring keeps the valve from leaking. Good Line Joints keep the linesand Filter bowl from leaking and the Electric keeps the pressure off the carb keeping it from leaking. Problem solved. ken
kenparker is offline   Reply With Quote
Old 01-10-2016, 10:31 AM   #18
Larry Jenkins
Thanks, Doug. Yes, we are all a little anxious when we post. I'm probably very guilty about that. You are absolutely right.
Mike.. Yes, that's my philosophy. BUT.. Where does it say that improvements can't be made? Did Henry know about "O" rings? Were they even around then?
Yes. reinventing the wheel sometimes is better..
Larry
Old 01-10-2016, 11:07 AM   #19
Mitch//pa
I didn't say this but what about buying a new one? Both my cars have new ones and they work perfect... If either fails I'll get another....
Old 01-10-2016, 11:35 AM   #20
700rpm
700rpm's Avatar
Larry, since no one here seems to have experience with o rings and shutoff valves, you could try this and give us a report on how it works out. If you do, I would suggest you first put the o ring in a small amount of corn gas for a month or two to see if the gas destroys the rubber before you install it on your shutoff valve.
Ray Horton, Portland, OR
