Old 10-12-2015, 05:14 PM   #1
runnin hot
Default Brattons new reflectors?
Has any one tried Bratton's newly tooled aluminum reflectors, part #17950?
I know some people have had issues with re-pop reflectors from different companies and not being able to focus them right, it looks like Bratton's have built these ones to original ford specs to get rid of the focusing point issues...just wondering if anyone has bought and tried these yet.
"Now what the heck was that noise????"
runnin hot is offline   Reply With Quote
Old 10-12-2015, 05:30 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Brattons new reflectors?
Yes, ...we have installed quite a few sets. "Night vs. Day" difference between the Vintique manufactured ones.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-12-2015, 05:34 PM   #3
Mitch//pa
Agree X2
Old 10-12-2015, 05:43 PM   #4
runnin hot
cool....now to wait for the exchange rate to drop, then order some up...lol, thanks guys, much appreciated.
Old 10-12-2015, 08:49 PM   #5
Al 29Tudor
Al 29Tudor's Avatar
Highly recommend them. I've been running them for a couple years and they are great - I also use the higher CP bulbs.
Al
Al 29Tudor is offline   Reply With Quote
Old 10-12-2015, 08:59 PM   #6
Bob Johnson
Bob Johnson's Avatar
I have done some research on reflectors and bulbs. To get the correct focus you have to have the correct bulbs for your reflectors. The reflectors which have the socket hole offset 1/16" from the center (like the later originals) require a bulb with the two filaments equal distance from the center of the bulb. The reflectors where the socket hole is in the center of the reflector use a bulb with high beam filament centered in the bulb and the low beam filament offset above the center.
Bob
Bob Johnson is offline   Reply With Quote
Old 10-12-2015, 09:39 PM   #7
runnin hot
Hmmm....I will have to check the bulbs I have, I know the ones in the truck right now have 2 filaments that are in a shape of a V or A...depending on how you are holding them, The new bulbs that I just got which have the higher wattage high, have 1 filament that is in the shape of a V and 1 filament that is straight across, with no bends or anything
Old 10-12-2015, 11:12 PM   #8
RonC
RonC's Avatar
If your night driving you need the brattons reflectors. Put your originals on ebay
RonC is offline   Reply With Quote
Old 10-13-2015, 12:00 AM   #9
RandyinUtah
I installed the new Bratton reflectors and noticed that by lights had a more yellow look then my old Vintique reflectors. I am using the new Halogen 6 volt bulbs that fit in the original sockets. Do you guys think I should try a different type bulb?
RandyinUtah is offline   Reply With Quote
Old 10-13-2015, 05:32 AM   #10
Mitch//pa
it could also be your lens
Old 10-13-2015, 05:34 PM   #11
RandyinUtah
I guess my question is should I use the Halogen 6 volt bulbs that fit in the original sockets or go back to a standard 32/50 cp bulb? I was hoping for better results from Bratton's new reflectors. If the yellow tint is from the lens can this be corrected or do I look for new lens? Thanks
Old 10-13-2015, 05:52 PM   #12
JtownJoe
JtownJoe's Avatar
I have the new reflectors from Bratton's and also the halogen bulbs and I am very pleased with the combo. My drivers side does seem to have a minor tint, I'm sure its from the glass lens, but all in all I'm not concerned about driving at night.
JtownJoe is offline   Reply With Quote
Old 10-13-2015, 06:01 PM   #13
updraught
updraught's Avatar
My guess is the halogens are sucking too much power for the wiring. Or trying to ...
Try connecting one light direct to the battery with heavy cables and see if it is then white. If it is, you need a relay and thick cables from the lights direct to the battery, thereby bypassing the light switch.
Do a search for "headlight wiring upgrade" for some ideas.
PS. This is a problem on some modern vehicles also where the manufacturers are too cheap to use anything more than two strand copper wire.
updraught is offline   Reply With Quote
Old 10-13-2015, 06:03 PM   #14
2manycars
2manycars's Avatar
I have installed these reflectors in a customer's car, and the results were great.
2manycars is offline   Reply With Quote
Old 10-14-2015, 04:23 AM   #15
dr.j
I have them as well and without doubt, they are the best money can buy.
Dave A Jamieson
Portland, ON
Canada
1928 Tudor
dr.j is offline   Reply With Quote
Old 10-14-2015, 08:09 AM   #16
BlueSunoco
I don't have them, yet. But, they must be good because a buddy that does have them told me that now people that he meets at night 'flash' their brights at him, his lights are too bright and that never happened before!
BlueSunoco is offline   Reply With Quote
Old 10-14-2015, 08:59 AM   #17
JohnLaVoy
JohnLaVoy's Avatar
We reviewed them when they came out. Did a whole test series and write up for the Times. They work very well.
JohnLaVoy is offline   Reply With Quote
Old 10-14-2015, 08:40 PM   #18
Jim in S.C.
I have them on a 30 pickup. One night an oncoming car flashed me asking me to dim my lights. I never had that happened before. well worth the price.
Jim in S.C. is offline   Reply With Quote
Old 10-15-2015, 12:55 AM   #19
runnin hot
ok...so here's another question...I have noticed several people make comments about how cars coming towards them flash their lights because of how bright the new defectors are....isn't that a bad thing? I know I get irritated when a car goes past me with it's high's on, or stupid aftermarket lights that aren't designed right.....isn't there a happy medium? Bright enough to see safely by, not too bright to on coming drivers...
Old 10-15-2015, 06:35 AM   #20
C26Pinelake
They make driving at night, a whole lot safer! At the cottage there are lots of deer run across the road at night and I now can see them much easier. Wayne
C26Pinelake is offline   Reply With Quote
