Old 12-01-2015, 08:57 PM   #1
40cpe
40cpe's Avatar
Default oil pump, again
I've torn my 8BA style oil pump down and glad I did. The relief spring had 3-4 coils broken. I have another pump and the spring in it looks good. The pump I'm planning to use didn't have a paper gasket between the cover and the housing but had a thin, hard sealer-like coating. I have a Best gasket set that includes a paper gasket but I've read suggestions not to use a gasket. If I don't use the gasket, should I use a sealer of some sort, and what is the recommendation? Should I do a trial fit dry and use plasti-gauge to check clearance? I've read about .005" is what to shoot for. Any suggestions welcome and appreciated.
Thanks.
Old 12-01-2015, 09:40 PM   #2
tubman
tubman's Avatar
Default Re: oil pump, again
I've just been through this, and my '49-'51 (reproduction) manual says .0015 to .006" clearance between the gears and the cover. As an example the clearance on mine was .002"
Old 12-01-2015, 10:06 PM   #3
40cpe
40cpe's Avatar
Originally Posted by tubman View Post
I've just been through this, and my '49-'51 (reproduction) manual says .0015 to .006" clearance between the gears and the housing. As an example the clearance on mine was .002"
Did you use a gasket?
Old 12-02-2015, 12:23 AM   #4
jetmek
don't use a gasket or sealer...
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 12-02-2015, 06:39 AM   #5
Diavolo
Diavolo's Avatar
My pump would have been an interference fit if I didn't use the thin gasket with my kit. The gears protruded .001 outside the pump body. The gasket left clearance for the gears to turn.
Check your clearances and don't just assume.
Diavolo is offline   Reply With Quote
Old 12-02-2015, 11:48 AM   #6
Bruce Lancaster
Ford didn't specify end clearance, as far as I can tell, but it is an important area that can drop your oil pressure. I use a spec (from memory, .005--7) that I borrowed from a Vizard book covering the SBChevy pump.
Old 12-02-2015, 01:39 PM   #7
tubman
tubman's Avatar
I used the gasket that came in my gasket set. For 8BA's at least, Ford has an end clearance specification.
Old 12-02-2015, 08:43 PM   #8
40cpe
40cpe's Avatar
I used plasti-gauge without the gasket and it showed .002" between the gears and the plate. I cleaned the plastic off and installed the plate. The pump was locked up. The gasket read .009" thick so I put it on and reinstalled the plate. It's all back together.
Old 12-03-2015, 06:09 AM   #9
JWL
The efficiency of the pump is compromised with excess end clearance. Keep it as tight as possible without contact between gear and cover plate. Fill the gear section with Lubriplate Motor Assembly lube after clearance is established and the pump will be ready to install.
JWL is offline   Reply With Quote
Old 12-03-2015, 07:39 AM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
JWL, what dimensional +/- spec. would you shoot for between rotor and plate when using a gasket?
John
Old 12-03-2015, 10:04 AM   #11
flatjack9
flatjack9's Avatar
If you have .002 clearance, one would think it should turn freely.
Old 12-03-2015, 10:46 AM   #12
Ol' Ron
Ol' Ron's Avatar
Back in the 90's the Mellings pumps were garbage, I won't go into it, but I had to replace several of them. Since then I just cleaned them, checked clearance and most have worked just fine. With my limited vision ai now have John do them for me. The 280 in my truck has 10lbs at hot idle and 40 at cruise. I use 5-20 oil.Will switch to a synthetic after brake in.
