Spark plug air compressor ?!?! Found in an old garage.
It's a champion spark plug in a special case. Sleeve allows air from engine compression to go to side pipe, which I believe would have a hose attached to fill tires up. So yes I guess it is a tire pump.
They were fairly common in the mid to late 50's in North Texas.....I was just a nipper but I remember my uncle raising the hood on his old international truck and airing up tires.
Just Passin' Thru.....Slowly! ![]() |
That is slick.
So I suppose you'd have to take it off when not in use, yes? Or is there a plug for the hose fitting so you could just leave it on the car? Last edited by jesselashcraft; 11-14-2015 at 06:36 PM. |
How do you keep the fuel mixture from entering your tire?
Just curious. |
You don't. There is no fire or flame inside the tire. No problem!
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
By the way, it is not a spark plug that would fit a Model T.
Thanks for the info. I saw the plug would not fit a T, but figured this forum would have the best, most knowledgeable participants to answer the question.
The fuel would make your tires perish from the inside as it slowly ate the rubber.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
dp is correct. More expensive units screw in in place of the spark plug and have a piston that is actuated by the combustion chamber mixture to pump fresh air.
#13 |
I agree with Layden and dp. The unit that I had years ago was similar to this one, but did not have any fuel mixture injected into the tire. It was like a small piston that used outside air. And yes, Royce, I figured it would be kind of tough to have a flame inside the tire, dah.
#14 |
they were sold by sears as a craftsman product in the mid sixties with different adapters for most of the sparkplug sizes. I have one I carry in my A and I used one of the adapters that you can buy to put 14 mm plugs in your A. Ed.
#15 |
My dad had one that he used to blow up air mattresses when we went camping. I don't know where he got it, but my guess would be Sears. That was the Wal-Mart of the forties.
