Old 09-19-2015, 01:45 PM   #1
Kurt in NJ
Kurt in NJ's Avatar
Default Howto make 6 inches into 12
With Hershey coming I figured I would share a method I thought up to measure brake drums with the cheap harbor freight 6" caliper---
Using any known size in the range you want to use this method you come up with a number to set the calipers at---then zero it
The older one in the picture the correction factor for 12" is 2.704---if you want to measure an 11 inch drum you use 1.704
I mark the correction number on the caliper, I have a newer "pittsburg" 9.95$ with coupon that the correction number is 2.717 for 12", I havn't checked at the store to see if it is close enough to use on others of that series
the brake drum in the picture is quite thin at .168 over 11 inches, the drum surface is only .020 thick
Old 09-19-2015, 02:05 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Howto make 6 inches into 12
Hmmm, not quite what I expected !
Old 09-19-2015, 10:16 PM   #3
CarlG
CarlG's Avatar
My wife asked the same question.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-19-2015, 10:36 PM   #4
H. L. Chauvin
Knew a guy who asked same of his doctor.
His Doctor replied, lots of products on market; but, none he knew of actually worked.
H. L. Chauvin is offline   Reply With Quote
Old 09-20-2015, 11:32 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
DON'T use VIAGRA, makes you see everything in WASHINGTON BLUE!!--Like the old song, "BLUE LADY WALTZ" I even remember the lyrics
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-20-2015, 10:04 AM   #6
ctlikon0712
ctlikon0712's Avatar
Great method Kurt, thanks for sharing. Not what I thought either.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 09-21-2015, 01:15 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I saw a cutaway display at the Gilmore a couple days ago.
When you see the stock drum, a very worn drum, and the new cast iron drum, it's easy to see why the cast drums offer so much better braking.
