Old 09-01-2015, 02:51 PM   #1
JAKEFORD
Default Improved Grease Gun Coupler
Has anyone tried a new coupler called "Lock-n-Lube". Its advertised on amaxon for about $30. Its claim is leakproof and easy on easy off.
JAKEFORD is offline   Reply With Quote
Old 09-01-2015, 06:14 PM   #2
Pinstripe
Default Re: Improved Grease Gun Coupler
Yes and it works well
Pinstripe is offline   Reply With Quote
Old 09-01-2015, 09:20 PM   #3
Fred K-OR
Fred K-OR's Avatar
Is this for the modern fittings?
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 09-01-2015, 10:15 PM   #4
160B
160B's Avatar
I looked at the photos on Amazon and it looks like it locks on the modern zerk fittings and would not work on the original Model a Ford grease fittings.
http://www.amazon.com/LockNLube-Grea.../dp/B00H7LPKKU
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 09-02-2015, 05:24 AM   #5
bobusnick104
bobusnick104's Avatar
I've never seen one of these and checked it out on Amazon. It has a lot of good reviews. One bad feature is that it won't fit in a tight spot, but I think it would work well on modern Model A fittings. It's worth a try as I hope it will eliminate wiping off excess grease.
It's only money, we'll make more tomorrow.
bobusnick104 is offline   Reply With Quote
