1928 Tudor -
If it's a stock head, now would be a good time to install a 5.5 head. Cracks in the head by the oval center hole are common and usually don't need to be fixed to be used.
What will the 5.5 head (high compression I assume), do for us? We're trying to learn as we go, so some of this is a little over our heads. The head on it looks like it is an original on the car and doesn't look like it's ever been bored. Are you saying we could just go ahead and bore the block for the .040 pistons and just leave the cracks? It's not going to be driven but around in our area - no long driving.
Greater top speed, lower operating temperatures, greater MPG are a few advantages. If you were to do a search you will find several threads on the topic.
As for the block, is it numbers matching to the frame and title? Yes get it stiched, no get another block. JMHO
Can you post pictures of the bottom of the head and the cracks? The 5.5 head gives some easy extra horsepower for not too much money, and it still looks stock. How much does the shop want to fix your head, which is crack repair and milling? For the little extra money, a new 5.5 head might be worth it, even if you are only doing local drives.
Just my two cents after many Model A,s for the last 50 years. Do not waist your money on fixing the old head. The new 5.5 head is a big improve meant over the old head.The block will have to be fixed.
The head on my car has a crack from water passage to head stud by dist ---hasn't been a problem in the 45 years I have been driving it ---I did drill. tap for small machine screw, then cut it off slightly above, peined with hammer, then surfaced with a file to interrupt the little valley ---the worst that will happen is the stud could get coolant around it, perhaps leak some out of the nut
A couple years ago, I had a pair of blocks and a pair of heads all fixed up using the pin method and welding. I had this shop in Illinois (sorry, not Texas) that specializes in these types of repairs do this, and the cost per item was very reasonable; all the work done was less than the cost of the high compression head I just looked up on Snyders.
Just something to consider, if you end up finding a shop local to you.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic |
