I have a 1931 slant window 160B. It was built in May of 31 as far as I can figure. I am replacing the running boards and I have found conflicting information as the the finish of the outer trim. Is it Zinc or Stainless. Also do you bend the vertical section of the trim so it wraps around to the side just slightly or just cut it straight down? A photo would be great. Thanks.
