Old 06-25-2023, 09:20 PM   #1
gwillford
Default 30 Murray town sedan rear door shims?
The rear doors on my 30 Town Sedan are rubbing on the curved bottom, About 1/3 up from the bottom of the door. Both sides. The door alignment of all 4 doors to the door opening, to each other, and to the body lines are good. It appears that all it needs is shims under the hinges to move the door forward a bit to clear. Before I make my own shims, are there any out there? The ones I have seen from the usual suppliers don't match my hinge hole pattern. Thanks for the help!
gwillford is offline   Reply With Quote
