Old 07-22-2015, 05:23 PM   #1
Gold Digger
Default New distributor installed
I had the distributor out of one of my "A's" and decided to use a new distributor that I've had saved back for when one of them got worn enough to replace. Wasn't really anything wrong with the one I replaced, just thought I would try the new one because it has the "B" cam. I couldn't believe it was the same car in the way it started, ran and performed. I have always had to choke a little to start it when it's cold starting, not now. Runs and pulls better. It even sounds different and idles smoother than before. I've had this distributor for at least 5 years and could have been enjoying it all of this time.
Gold Digger is offline   Reply With Quote
Old 07-23-2015, 08:02 AM   #2
V4F
V4F's Avatar
Default Re: New distributor installed
good for you !
V4f
V4F is offline   Reply With Quote
Old 07-23-2015, 08:12 AM   #3
Henry1953
Henry1953's Avatar
The B cam really made a difference in mine as well. It definitely makes a hotter spark.
Henry1953 is offline   Reply With Quote
