Hi,
Could someone please tell me what I am looking at here? I am rebuilding the brakes on my 1930 coupe and found 2 different hubs on the front. Actually also found 2 different hubs on the rear but I found the explanation of that (protruding ring vs. groove). Anyway I am curious about these front hubs. Are they both Model A hubs? Of different years? Is one a repop? The right hub has stamped tabs that appear to be to hold the outside bearing race. Also that drum was a greasy mess inside while the left was relatively clean. Thanks, Jerry image.jpg Last edited by Fillinjc; 07-09-2015 at 10:14 PM. Reason: Correction |
When we were installing a club member's drums on his old hubs we saw the same thing. We could not offer an answer to the difference either. Perhaps a Barn member has the answer.
John |
One early 28 hub and one later hub. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
I found the same on my 29 coupe. One front hub was a 1928 and the other 1929. Also the wheels are different. The 28's have a thinner center hub on the wheel than the 29. If you do have different wheels, don't change them on the hubs. The 28's don't work on the 29's.
I also had the same situation on the rear like you mentioned. I wanted cast iron drums so I sent the hubs and drums to Bert's in Denver and asked Steve to supply me with a matched set of 4 hubs and put new cast iron drums on all 4. He did a great job and then I found all 1929 wheels to work for the 1929 hubs.
Is the right hub the 1928?
Thanks, Jerry |
#7 | |
![]() Quote:
#8 | |
![]() Quote:
