Old 07-04-2015, 02:38 PM   #1
Steve Plucker
Default February 1929 Tudor front floor mat...
Very interesting here, I was thinking that the February 1929 Tudor came with a rubber floor mat. But there are no attachments (studs) what so ever to attach the rubber mat to the subframe. With that observation, the front floor cover had to be carpet but the standards says the carpet ended "mid 1928" (say August 1928) and the rubber mat then came into being.
Another interesting fact about this February 1929 Tudor plus a few other things.
Would there have been carpet fasteners then on the front floor boards if that was the case? Guess I will have top brave the heat and go out into the wearhouse to look.
The rear mat is deffenitly carpet.
Thanks.
Pluck
Old 07-04-2015, 02:48 PM   #2
hazelhoff
hazelhoff's Avatar
Default Re: February 1929 Tudor front floor mat...
Dear Steve, the Standards are man-made, so the carpet is not excluded to the diary. Many peolple do not live up to standards after all.
Henk
hazelhoff is offline   Reply With Quote
Old 07-04-2015, 04:15 PM   #3
wrndln
Steve,
I think carpets used mat studs to secure the carpet. I was pretty sure tudors had rubber mats, but I could be wrong. The judging guidelines show rubber mats used for late 28 and 29 tudors. Are you sure someone didn't remove the studs? Most of my cars have at least some of the studs missing, but not all of them. You should sent an email to Gary Karr and ask what he did on his Henry award winning 29 tudor. I don't know what month his car is, but I vaguely remember it was manufactured in the first half of 29.
Rusty Nelson
Old 07-04-2015, 05:49 PM   #4
Great Lakes Greg
Great Lakes Greg's Avatar
My March 6th. '29 Tudor has the studs.
Great Lakes Greg is offline   Reply With Quote
Old 07-04-2015, 06:42 PM   #5
Steve Plucker
Originally Posted by wrndln View Post
Steve,
Rusty Nelson
Rusty,
Yes, I am very sure on that one...No studs have ever been removed if they were there at all. If the rear mat was carpet, which it is in this Tudor, would not the front be carpet also?
Did the Tudors ever have a rubber mat in the back?
Pluck
Old 07-04-2015, 08:03 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
My 2-23-29 Tudor has the rubber mat studs.
Original rubber mats had fabric reinforcing molded in around the holes.
Old 07-04-2015, 09:27 PM   #7
mot
Registered User
mot's Avatar
here is an original fordor
it had rubber in the front and carpet in the rear
dont know which year or month it was (28 or 29)
tom
mot is offline   Reply With Quote
Old 07-04-2015, 09:27 PM   #8
Gary Karr
Gary Karr's Avatar
Steve,
Rusty Nelson
My early Feb '29 Tudor does have rubber mats both front and rear and did come with the mat stays although some were missing before I restored it.
Gary Karr is offline   Reply With Quote
Old 07-04-2015, 09:51 PM   #9
Steve Plucker
I am beginning to think that this February 1929 Tudor body of mine just might be earlier that I think. It has the carpet in the rear...Hard telling what was up front. The original upholstery door panels ar the next generation without the special band on top.
Thanks Guys.
Pluck
Old 07-05-2015, 01:18 AM   #10
Tom Wesenberg
Door panels without the top trim band would be correct for early 29 wouldn't it?
Old 07-05-2015, 07:43 AM   #11
2manycars
2manycars's Avatar
My january 29 tudor has the hollow studs to hold the mats, front and rear.
2manycars is offline   Reply With Quote
Old 07-05-2015, 08:57 AM   #12
Steve Plucker
Yes it would Tom...That is what's funny about it plus a few other things such as the two holes, left and right, in the front coss member for the two engine splash pans...suposed to be deleted by December 1928 or there abouts.
But back to this issue...If in fact this car came with a carpet type front floor mat...would it or would it not have the studs in the subframe?
Again, not one is there...not one BUT the holes are there.
Pluck
Old 07-05-2015, 09:50 AM   #13
Steve Wastler
Steve Wastler's Avatar
Not sure on Tudors specifically, but my 28 fordor has 'mat' studs' for the front carpet 'mat' at firewall and in front of riser. Rear carpet 'mat' has front and rear studs as well. I would think Ford used the term 'mat' for both carpet and rubber if they weren't permanently fastened.
Steve Wastler is offline   Reply With Quote
Old 07-05-2015, 09:52 AM   #14
Steve Wastler
At firewall
Old 07-05-2015, 09:54 AM   #15
Steve Wastler
Rear
Old 07-05-2015, 10:02 AM   #16
Steve Plucker
I am beginning to think that the Assembly Plant just ran out of the studs and did not even put them into the car in this case. There is nothing there telling me that it was a "carpet" type mat or a "rubber" type mat that was originally used in the front seat area of this Tudor. Not on the original floorboards or the sub assembly.
But since it has an original "carpet" mat in the back, guess I will put a "carpet" type mat in the front.
Anyone with an original "carpet" type mat to fit a 1928 Tudor Sedan?
Pluck
Old 07-05-2015, 01:57 PM   #17
Gary Karr
Gary Karr's Avatar
Mat stays on the Ford bodies are installed like a semi-tubular rivet with the end peened over and could have easily been pulled out when the mat was pulled up.
Old 07-05-2015, 05:15 PM   #18
Steve Plucker
Vince:
Why do you say it had to be carpet, because it does not have mat studs? Sounds like you are missing the carpet studs as well. Seems from the timing that the car would have mats, not carpet, and the studs have gone broken or missing over the years. Also a note from the JS:
Gary:
Me:
I do not disagree with any of those thoughts, but here is the thing, first, the rubber mat stays, all six, are not there nor are there any tell tale signs of them being there in the first place by the way the original paint looks in those six areas. Second, there are no carpet fasteners to fasten the carpet to if that were the case.
So I guess it is six of one and 1/2 a dozen of the other.
So here is my question: When Ford went from carpet to rubber floor mats in the 28-29 Tudors, was it done at the same time OR was there always a carpet in the back area with a rubber floor mat up front?
Thanks.
Pluck
Old 07-06-2015, 12:55 AM   #19
Tudortomnz
Tudortomnz's Avatar
Originally Posted by Steve Plucker View Post
Vince
Thanks.
Pluck
Who can answer this?
I would be checking out all the original early Tudors in your area for a start.
Front mats have always taken a beating & the rubber they used back then dried out & lacked durability. It is strange your car lacks the mat studs.
If it interests you, my Tudor has the rear rubber [ Baldwin, Pontiac, Mich.] mat but the front one was gone at 64,000 miles. It now has a repro RHD rubber mat that looks like it will outlive the car.
Cheers
Tudortomnz is offline   Reply With Quote
