Are there any articals published on drilling a model A crank rods and main s ?
#2 | |
![]() Quote:
However, after having spoken to a number of very experienced automotive machinist, they advise having someone with proper tools and EXPERIENCE with this job...to accomplish it best. If you contemplate what can happen , if this job is done wrong, you can understand what is at stake, if done wrong. I've often wondered if a guy might 'practice' accuracy/technique on worn out disgarded cranks, to acquire the necessary skills to have success. I guess that you only get one chance to do it right on a good crank, eh ? |
Others will no doubt contradict me but I wouldn't drill a model A crank shaft. Don't ask how I know but they are not strong enough to take it without increasing the likelihood of breaking.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
A few years ago there was a thread on here about the Model A powered Pietenpol homebuilt plane from the '30's. Someone posted detailed drawings from the day showing how to convert the A engine to aircraft use, including full pressure oiling with a drilled crankshaft. If it held up in the air, should be OK for road use!
I once got a Dayton Globe aero engine from Bill Trone's estate. Bottom part was pure A (crank, rods, cam, timing gears, oil pump). Fascinating thing. Now powering a trials car in England.
#8 | |
![]() Quote:
Sealing the rear main is a challenge but it can be done Drilling the crank is 1 of those things there are 3 different ways to do it and it must be done by someone with experience I would recommend using the 3 angle method if you find someone with experience Do plenty of research before starting |
#9 | |
![]() Quote:
https://www.fordbarn.com/forum/showpo...7&postcount=31 Here is a large version; http://www.antiqueairfield.com/types...onversion.html
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 06-15-2015 at 04:37 AM. |
Jim Brierley has published a book on the 4 banger and covers how to go about this and whether or not you actually need full pressure for your application. Look him up on here. Its a good read for anyone considering go fast parts on their model A or B.
Clearly pressurizing the A can be done, but in reality it is only needed for a few highly modified engines. The splash oil system is extremely effective for many modified engine builds.
I think it would be wise to explain what you are doing to the engine and ask if it really needs the pressure. |
Why waste time doing something that is commercially available in a much better form? Call SCAT and order what you want already balanced and drilled.
http://www.model-a-ford-4bangers.com/ |
#13 | |
After reading much about how the Model A water pump pushes the water faster than the radiator can flow, I was not surprised to find the below statement in the attached link that Mike provided. Interesting....
http://api.viglink.com/api/click?format=go&jsonp=vglnk_143436906135211&key=47 8da9cdb93cd3bfc02976eee2c19bf0&libId=iaxto9pi01002 5g6000DAc142dygf&loc=http%3A%2F%2Fwww.fordbarn.com %2Fforum%2Fshowthread.php%3Ft%3D171187&v=1&out=htt p%3A%2F%2Fwww.antiqueairfield.com%2Ftypes%2FCorben %2Fcorben-ford-a-conversion.html&ref=http%3A%2F%2Fwww.fordbarn.com% 2Fforum%2Fforumdisplay.php%3Ff%3D3&title=full%20pr esureing%20a%20Model%20A%20-%20The%20Ford%20Barn&txt=http%3A%2F%2Fwww.antiquea irfield.com%2Ftypes...onversion.html Quote:
Wanted: Simmons Super Power Head ![]() Craig Likon 1931 150B |
#14 | |
![]() Quote:
