Old 05-24-2015, 10:01 PM   #1
Stokes
Default Replacing key lock on 1938 Standard Sedan Trunk Lever
I'm in the process of getting all my locks working-My passenger door now works fine but need to replace lock on truck lever-any tips?
Stokes is offline   Reply With Quote
Old 05-24-2015, 10:02 PM   #2
Stokes
Default Re: Replacing key lock on 1938 Standard Sedan Trunk Lever
I meant Trunk Lever😁
Old 05-25-2015, 12:31 AM   #3
ford38v8
ford38v8's Avatar
You can edit your original post anytime. Look to the blue buttons on the bottom of your own post.
Alan
Old 05-25-2015, 03:45 AM   #4
Snouts out
Look up the ford barn lock guy! I'm sure he has a cure.
Snouts out is offline   Reply With Quote
Old 05-25-2015, 03:53 AM   #5
Fe26
If you have a key that fits into the cylinder (it doesn't have to open the lock) insert the key, using a piece of wire insert that into the small hole near the cylinder and depress a small pin at the end of the hole. Turn the key about a quarter turn and pull the key and cylinder out of the lock.
Fe26 is offline   Reply With Quote
Old 05-25-2015, 06:54 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I had a '39 trunk handle that I tried to get open for a fellow Fordbarner. It had a key that would go in the lock but would not turn the cylinder. I was told by several locksmiths who post here, that the cylinder must be in the open position to get to a spring loaded pin that must be pushed in to remove the cylinder. I have a small collection of old Ford keys, and of course none would open the lock. Long story short, I mailed the complete handle to Leon Rowell (I think he goes by the handle "LockDoc" here on Fordbarn) and he promptly opened the lock, removed the cylinder, cut new keys, and mailed the handle to the owner. All of this was done quickly at a very reasonable price.
https://www.fordbarn.com/forum/showthread.php?t=98946
John
Old 05-25-2015, 08:07 AM   #7
32phil
Stokes...FYI ...the key from your glove box lock(if so equipped should open your trunk) if not send me a PM and I'll try to help
Phil 845 551 5132
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 05-25-2015, 05:17 PM   #8
Stokes
Thanks Phil-but I do not have a locking glove box-Dan
