Old 05-13-2015, 06:41 PM   #1
Init1
Init1's Avatar
Default 40 banjo mixed up parts ...HELP
Getting frustrated. I have a 40 banjo that came out of a driving car.
I rebuilt it even with marginal axle threads but now have decided to replace the axles with better ones. The passenger side also has about 1/8" end play that wasn't there before I took it apart. The drivers side is ok.
Soooo, I picked up some replacement axles and a nice complete diff with spiders. All supposedly 40 Ford.
Went to test assemble the axles in the diff and the gears don't appear to mesh
Properly.
Spiders are 11 tooth and the axles are 18 tooth.
The axles measure 31 15/16".
What the heck do I have and what do 40 banjos have for spiders and axles? And what is causing the end play?
Any and all help greatly appreciated.
Init1 is offline   Reply With Quote
Old 05-13-2015, 06:55 PM   #2
Bob C
Default Re: 40 banjo mixed up parts ...HELP
According to the green book 39-41 axles are 16 teeth 32.85" long.
Bob
Old 05-13-2015, 09:06 PM   #3
ford38v8
ford38v8's Avatar
There were both 16 and 18 tooth axles, either set will work in your differential, but must be mated with their spider gear. Your axle length is a mystery to me, however. Below is an article from Street Rodder magazine that can help identify what you have.
http://www.flatheadv8.org/fordrear.htm
Alan
Old 05-13-2015, 09:18 PM   #4
Henry/Kokomo
Henry/Kokomo's Avatar
I'd do a lot of measuring. It's possible you don't have what you were told you have - i.e. not a '40 rear end or not all '40 parts.
Henry
Henry/Kokomo is offline   Reply With Quote
Old 05-13-2015, 09:25 PM   #5
Binx
Check this out...
Lonnie
Binx is offline   Reply With Quote
Old 05-13-2015, 09:52 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
Properly.
Can you post some pictures of the parts and pieces you are trying to assemble? Do you have access to the internet articles that give instructions on how to put a Ford banjo rear together?
John
Old 05-15-2015, 10:33 AM   #7
Randy
Randy's Avatar
1935-41 passenger axles are the same length, 32.85", but 1935-38 axles have 18 teeth whereas 1939-41 axles have 16 teeth. So, you can use either 16 or 18 tooth axles in any 1935-41 passenger rearend, but you must use the 12 tooth pinion gear with the 18 tooth axle shaft and the 11 tooth pinion gear with the 16 tooth axle shaft.
The shortest axle shaft with 18 teeth that I see in the chassis parts catalog for 1928-48 is 32.18", which is for 1932-34 V8s. Are you measuring the axle in overall length, tip to tip?
Randy is offline   Reply With Quote
Old 05-15-2015, 11:07 AM   #8
JSeery
JSeery's Avatar
As with most flathead stuff, the 1938 rear axle was a transition year and you can not be sure of what you have (axle tooth count) without checking. But as a practical matter this applies to almost any year because to the age of the vehicles who knows what has be changed over the years!
Old 05-15-2015, 12:29 PM   #9
Init1
Init1's Avatar
Guys...
Carefully remeasuring with the lights on my axles are 32.85" and have 18 teeth.
I need a set is 12 tooth spiders.
Old 05-15-2015, 12:43 PM   #10
ford38v8
ford38v8's Avatar
You have everything you need. Use the spider that came with the replacement axles.
Alan
