Old 04-16-2015, 09:13 AM   #1
a-bone newby
a-bone newby's Avatar
Default motor mounts
can anybody help les andrews says to remove motor mounts forward and mount manufacturer says to the rear ? I am confused.
a-bone newby is offline   Reply With Quote
Old 04-16-2015, 10:10 AM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: motor mounts
Are you refering to Float A Motor mounts?
If the object is to remove the mount, it doesn't matter which way you remove them.
Farrell In Vancouver is offline   Reply With Quote
Old 04-16-2015, 08:45 PM   #3
a-bone newby
sorry original steel mounts?
Old 04-16-2015, 09:06 PM   #4
Goldhardt
Goldhardt's Avatar
I removed mine last week. I just took out the three bolts and yanked them out. They just set in the frame. They were stuck a little bit because of the old deteriorated rubber, but there is no certain way to pull them off that I can see.
Goldhardt is offline   Reply With Quote
Old 04-18-2015, 10:21 AM   #5
a-bone newby
thanks I will just rip them out
Old 04-18-2015, 11:54 AM   #6
V4F
V4F's Avatar
don't bust them !
V4f
V4F is offline   Reply With Quote
Old 04-18-2015, 01:19 PM   #7
a-bone newby
never I wouldnt destroy any A parts alwys take time to research techniques for removing parts someone always needs them thanks
