Old 04-17-2015, 03:36 PM   #1
Redbird
Redbird's Avatar
Default Headlight disconnect
I am trying to remove the radiator for the first time and need a little help. Hood is off, radiator drained, hoses disconnected, horn wire disconnected. I need to unplug the headlights to pull the wire out of the conduit and radiator shell. How do you unplug/disconnect the headlights? See pic attached.
John
Redbird is offline   Reply With Quote
Old 04-17-2015, 04:26 PM   #2
msmaron
msmaron's Avatar
Default Re: Headlight disconnect
To remove where you are showing, twist the outer ring and it will drop down., You should remove the front rims with the lens to see if you have the 2 words wired tired to be able to remove them. There is a little latch under the headlight rim that has a spring and when you push back from standing in front of the car it will come loose and pivot down, then you can remove the rims, lens, bulb and the reflectors,. DO NOT touch the reflector with your hand and get oils on it.. use a soft cloth and then you can see behind where the wires are...Good luck...
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 04-17-2015, 04:27 PM   #3
CarlG
CarlG's Avatar
If your headlights haven't been re-wired (many of them have), just twist the ferrule at the base of the bucket counter clockwise about an eighth of a turn and it should pull right out. If they have been re-wired, it's anybody's guess as to how they are, but most probably you will have to go at it from the front by removing the lens and reflector.
(Mark is a faster typist)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-17-2015, 07:16 PM   #4
Redbird
Redbird's Avatar
Headlights have not been rewired. They had the twist off as you said. The radiator is out and any all screws/parts are soaking in EvapoRust. Should the screws that hold the radiator shell on have the square nuts? One side did and one had hex nuts. I will take the radiator to the shop tomorrow or Monday and let them work their magic, being careful not to use over 4 lbs pressure to test.
Old 04-17-2015, 07:19 PM   #5
Mitch//pa
Yes square nuts
Old 04-17-2015, 07:25 PM   #6
Redbird
Redbird's Avatar
Thank you Mitch.
Old 04-17-2015, 07:40 PM   #7
Goldhardt
Goldhardt's Avatar
Hey Redbird, after looking at your 3rd picture, you may to put a piece of felt on your radiator apron. Now's the time since you have the radiator and shell off.
Felt Pads
For the front radiator splash apron. Rivet or glue to the splash apron to prevent rattles between the apron and radiator shell. The 1928-29 models use two and the 1930/31 use only one. U.S.A.
Part Number: A-16529-AS 1928-29 $1.25 / pr.
A-16529-BS 1930-31 $0.75 / ea.
Goldhardt is offline   Reply With Quote
Old 04-17-2015, 09:02 PM   #8
J Franklin
J Franklin's Avatar
Also, now is a great time to give the engine a new shot of genuine Ford model A green paint. Never an easier time!
Old 04-17-2015, 09:20 PM   #9
Redbird
Redbird's Avatar
Goldhart, I'll take one of the 30/31 felts if you are selling. Do the auto parts stores carry the Ford green paint?
Old 04-17-2015, 09:59 PM   #10
John Duden
John Duden's Avatar
the parts houses carry the felts and the paint, I would recomend powerwashing the block down and drying off very good, Take any loose paint off with a power washer and a steel wire brush. then when good and dry, take a can of engine paint and Brush paint it,
John
John Duden is offline   Reply With Quote
Old 04-17-2015, 10:12 PM   #11
Goldhardt
Goldhardt's Avatar
Redbird, I'm not a seller or anything like that. I copied the picture and prices from the Snyder's website. I do know that they also sell the Ford green engine paint. Other places sell them as well, but I use them quite a bit because they are one of the closest suppliers to me.
Not trying to sell you anything, just spending your money!
Old 04-18-2015, 06:58 AM   #12
Redbird
Redbird's Avatar
Thanks.
