Old 04-21-2015, 10:46 AM   #1
29ModelA
29ModelA's Avatar
Default Sign of a blown head gasket?
Took my car on a short drive the other day, about 5 miles round trip, with a 20 minute stop halfway.
It overheated, it has never overheated. It runs fine, runs as normal actually, I look under the hood and see this:
Is this a sign I blew the head gasket?
1929 Model A Barn find. California car, just a few more parts to find.
Interior, steering box (rebuild), and I am sure much more!
29ModelA is offline   Reply With Quote
Old 04-21-2015, 10:53 AM   #2
V4F
V4F's Avatar
Default Re: Sign of a blown head gasket?
get a radiator gas tester . positive results .
V4f
V4F is offline   Reply With Quote
Old 04-21-2015, 11:15 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
A compression test is a sure way to detect a blown head gasket if the leak involves a combustion chamber. Otherwise a coolant pressure test should be done.
Bob Bidonde
Old 04-21-2015, 11:17 AM   #4
Tiny
Tiny's Avatar
How does the oil look? If it looks like a milkshake on the dipstick you have problems
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 04-21-2015, 11:25 AM   #5
29ModelA
29ModelA's Avatar
Oil looked good, and I did not see any white smoke out the tail pipe.
Old 04-21-2015, 12:13 PM   #6
OL JENNY
OL JENNY's Avatar
Where do you find a radiator gas tester?
OL JENNY is offline   Reply With Quote
Old 04-21-2015, 12:44 PM   #7
Tiny
Tiny's Avatar
Stick you nose down in the radiator neck. You might be able too smell the exhaust in the coolant. I would do an oil change just to make sure you have no water in the oil.
Blackwall Panthers
Nor Cal chapter
Old 04-21-2015, 01:16 PM   #8
mshmodela
mshmodela's Avatar
Appear your plugs might be Motorcraft TT10... I was of the understanding those are relatively colder plug (better for higher compression heads)... So I'm guessing you likely drive on longer trip often?
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 04-21-2015, 01:25 PM   #9
WestCoast
signs of a bad head gasket, milky looking oil, steam out the exhaust pipe, a miss firing cylinder, rust around head and block, over heating, a pure white spark plug, no carbon on it, low compression on a cylinder, some times low compression on two a joining cylinders, but what the pic shows is a water leak around a head stud, re torque head bolts, you might try putting in some bars leak or silver seal head gasket sealer, but looking at that pic it doesn't look like any thing serious at the moment
WestCoast is offline   Reply With Quote
Old 04-21-2015, 02:00 PM   #10
C26Pinelake
Snyders sell a ceramic sealer for blocks and heads and it works great.
Wayne
C26Pinelake is offline   Reply With Quote
Old 04-21-2015, 02:12 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Try torqueing the head, warm it up & add a jar of Standard old "BARS-LEAKS"& SEE WHAT HAPPENS WHEN YOU DRIVE IT 20 MINUTES, OR SO.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-22-2015, 09:30 AM   #12
Glenn of northport
Glenn of northport's Avatar
Amazon shows a gas tester but I am not sure this one will work on model A
Glenn of northport is offline   Reply With Quote
Old 04-22-2015, 10:00 AM   #13
FRANK PKNY
FRANK PKNY's Avatar
napa hAS THE EXHAUST GAS TEST KIT IT'S NOT VERY EXPENSIVE, YOU WILL NEED TO WARM THE ENGINE UP. PUT THE RUBBER PLUG IN THE TOP OF RADIATOR AND SEAL AROUND IT WITH DUCK SEAL (HOME DEPOT CHEAP) FOLLOW INSTRUCTIONS WITH THE KIT. IT DON'T LIE IT'S THE SURE FIRE WAY TO TEST ANY ENGINE FOR A BLOWN HEAD GASKET, as FAR AS A FIX IN A BOTTLE i DON'T EVER DEPEND ON THAT FOR A PERMANGANATE REPAIR. jmho
FRANK PKNY is offline   Reply With Quote
