Does anyone have the modern bearing and race numbers for the 35-36rearend and the 42-47 1/2 ton pickup pinion shaft. I am using the 42-47 pickup center section and 35-36 axle housings along with the 37-41 axles to make a slightly narrower open drive shaft rearend and want to look through the 200+ new bearings and races I have to see if I have the ones I need. Thanks Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
