Old 03-25-2015, 11:06 AM   #1
miff
Default As bell housing
I am getting ready to set up my aa bellhouesing with the s10 t5 trans. I have the right adapter . I have two questions: one I need to make an adapter to use with the original brake and clutch . Aa bellhouesing does not have one . Any suggestions or pictures would be helpful . Two I understand the the input shaft on the t5 is to long to fit the model a flywheel . I have all the pilot bushing , bearing to adapt the input shaft .what I am looking for is the amount to cut off( shorten)the shaft . Or will it work with out any modifications. Thanks for your input. Miff
miff is offline   Reply With Quote
