Old 05-11-2011, 11:36 AM   #1
3Deuce40
Default Deuce gas tank
Does anybody know how much you need to modify a deuce gas tank when installing a quick changer rear end? How much do you lose gallon wise?
3Deuce40 is offline   Reply With Quote
Old 05-11-2011, 11:41 AM   #2
Krylon32
Default Re: Deuce gas tank
Depends on the rear. I've been doing some chassis with Winters V/8 rears and not cutting the tank. The distance from rearend center line to the rear of the case is about 1 inch less than a Halibrand. I also use acorn nuts on the cover for a little more clearance.
Krylon32 is offline   Reply With Quote
Old 05-11-2011, 12:09 PM   #3
3Deuce40
Thanks for the info. Would like to do a quick change style rear but really dont want to cut the tank. Its small enough already
