Old 03-20-2015, 05:27 PM   #1
Doug in NJ
Doug in NJ's Avatar
Default Horn Painting Strategy
Hello,
I started working on restoring my horn. I am wondering: it looks like each sheet metal part was originally dipped before assembly. But what is the best way to re-paint it? Before or after assembly?
Thanks,
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 03-20-2015, 06:07 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Horn Painting Strategy
I painted mine apart using PPG DP-90 and DCC 9000 gloss black. I should have had my air hose handy to blow on the screen though. Some of the holes filled with paint, just as the originals did back in 1928.
Old 03-20-2015, 07:59 PM   #3
C26Pinelake
I had mine powder coated and it looks great !
Wayne
C26Pinelake is offline   Reply With Quote
Old 03-21-2015, 07:02 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
"POWDER" coating is also whut keeps the OLD LADIES lookin' GOOD!!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-21-2015, 07:21 AM   #5
Kevin in NJ
I bent wires such that there were two bumps and fit very tight into the screw holes. This grab the parts tight and allowed me to rotate the parts. It did not leave any mark like you might get if you just looped through the holes.
Old 03-21-2015, 12:16 PM   #6
Jim Mason
Jim Mason's Avatar
Yes originally the parts were dipped seperately. Heres the inside of motor cover for an early EA horn. Notice the un-painted area caused by the air bubble...
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
