Old 03-06-2015, 03:22 PM   #1
Jwilli
Jwilli's Avatar
Default Timing gear past it's prime
Now I know why there is no spark.
Jwilli is offline   Reply With Quote
Old 03-06-2015, 03:23 PM   #2
mshmodela
mshmodela's Avatar
Default Re: Timing gear past it's prime
Now comes the question Fiber or Aluminum?
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 03-06-2015, 03:25 PM   #3
Jwilli
Jwilli's Avatar
From what I read on the forum, aluminum would be the best investment.
Old 03-06-2015, 03:27 PM   #4
mshmodela
mshmodela's Avatar
The cost is about the same... I guess the only down side to aluminum is from what I've read a little more noise. FrankW on this forum replaced his with Aluminum, you you may wish to ask his thoughts on it...
-Mike
Cleveland, Ohio
Old 03-06-2015, 03:49 PM   #5
Jwilli
Jwilli's Avatar
This engine is in the 29 clampet mobile, AKA the Anna Mobile. Noise will not be a problem.
Old 03-06-2015, 03:56 PM   #6
tbirdtbird
that metal gears make more noise is a myth. Aluminum and bronze are metal, but soft metals. Whole different story if you had steel against steel
in this case, the fiber gear did what they are all known to do: disintegrate
too many threads on this already
'31 180A
tbirdtbird is offline   Reply With Quote
Old 03-06-2015, 04:08 PM   #7
MrBruce
MrBruce's Avatar
I don't agree with tb, I had an aluminum on a B motor and it was loud. I took it off and went back to fiber. This will start a fire storm.
MrBruce is offline   Reply With Quote
Old 03-06-2015, 04:53 PM   #8
tbirdtbird
if that was the case then you had a mesh problem. Your centerline to centerline distance was off....you had too much lash
'31 180A
Old 03-06-2015, 05:20 PM   #9
snagglewhen
I bought gears from Dan McEachern out in CA on tb's advice. I have not had the chance to install them yet (school and all that), but they look amazing.
I went ahead and bought both, but you can just buy one or the other. One is bronze and the other is heat treated steel.
snagglewhen is offline   Reply With Quote
Old 03-06-2015, 05:22 PM   #10
CarlG
CarlG's Avatar
This is what I used also.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-06-2015, 05:38 PM   #11
Logan
Logan's Avatar
If your metal gears are loud, your block line bore is off in one direction or another. If its done correctly, you wont hear the gears.
Cowtown A's
Logan is offline   Reply With Quote
Old 03-06-2015, 05:56 PM   #12
Jwilli
Jwilli's Avatar
Those gears are to pretty to hide inside an old engine.
Old 03-06-2015, 06:29 PM   #13
James G.
How about 30,000 miles on a fiber timing gear? Working for me.
James G. is offline   Reply With Quote
Old 03-06-2015, 06:33 PM   #14
Jwilli
Jwilli's Avatar
This engine will probably not be driven more than 500 miles. I have a newly professional rebuilt engine that I plan to put into this toy for a breakin period. Just wanted to wait until warm weather.
Old 03-06-2015, 07:36 PM   #15
tbirdtbird
"How about 30,000 miles on a fiber timing gear? Working for me."
That is great!
keep an eye on it. Pull the side cover now and then and inspect.
Remember when it does trash itself you will have to do more than change the gear out.
You will have to drop the pan and clean the mess created so that shreds and pieces do not clog your oil pump.
'31 180A
Old 03-14-2015, 03:04 PM   #16
Jwilli
Jwilli's Avatar
OK I got a new timing gear and the tool to remove the old one.
I have tried an impact wrench with 150 pounds of pressure. I have clamped old timing gear. I have used torch and heated well. I have used a chisel with about a 5 pound hammer. I haven't moved the nut at all.
I am spraying it with a mixture of acetone and ATF. What do I try next?
Old 03-14-2015, 03:42 PM   #17
CarlG
CarlG's Avatar
You could always just buy a new Bill Stipe IB330 camshaft to go with your new timing gear.
Alaskan A's
Old 03-14-2015, 04:14 PM   #18
Jwilli
Jwilli's Avatar
The engine is still in the car. Radiator removed. I will soak it good for a day or two. If the impact wrench won't loosen it then, I will get the drill and give that a try. Thanks for the help. I think I will buy the hex nut to replace this old one.
Old 03-14-2015, 04:21 PM   #19
CarlG
CarlG's Avatar
... I think I will buy the hex nut to replace this old one.
Good choice. I wish I had thought of that when I went thru all this a while back.
Alaskan A's
