I am trying to figire out exactly where welting and or anti sqeak lining is supposed to be installed. I am rebuilding my entire cowl including new subrail extensions, cowl sides and firewall, Using the original fuel tank. Does anyone have a diagram or picture that shows this?
The cowl and gas tank welting in installed between the cowl and A pillar and goes up over the top of the gas tank between the gas tank and the filler piece above the gas tank and down the other side to the bottom of the cowl. On piece is used to do the whole thing. There is no welting between the top of the cowl and the bottom of the gas tank. You can see the welting in the picture. Pretty much all model A built by Ford had the cowl/gas tank welting installed the same way.
Rusty Nelson ![]() |
Tudor or Fordor?
Mine is a tudor. Thank you for the picture and explanation. Is there anything that should be placed under the tank? I see in the vendors catalog lists a gas tank anti squeak welting?
Rusty Nelson |
