Old 02-25-2015, 07:30 AM   #1
HS
Default Station Wagon 150B Guys, Bolts
Hey guys,
I'm starting back to work on my early 1931(150 B) Woody project after several years and a move across state to a new home. I can't locate all my Woody body Bolts to assemble the woody "box" together.
Does anyone make a "Bolt Kit"? for the Station Wagon How about Carl at Pleasantville MFG company, in Dewittville, NY He makes woody bodies.
Your help would be appreciated!!
Thanks,
Hugh
HS is offline   Reply With Quote
Old 02-27-2015, 10:14 PM   #2
henry's 31
Default Re: Station Wagon 150B Guys, Bolts
Hi Hugh:
Contact Mr. Jim Johnstone at 956-686-8162. He is the Guru of the MOdel A Woody Wagon Club. He may be able to point you in the right direction. You may want to also join that group.
Henry's 31
henry's 31 is offline   Reply With Quote
Old 02-28-2015, 01:22 AM   #3
pat in Santa Cruz
pat in Santa Cruz's Avatar
definitely contact Tim Johnstone. The screws and body bolts are available, but not particularly from one source, nor ID'd as for a Model A station wagon. Of course, for the exposed body bolts, such as for the top corner irons, you do not want the modern, thin headed and marked bolts. You want the thick head, old style and thick nuts as well. The flooring is bolted with a very wide and flat headed carriage bolt, called a step bolt, which are available from Restoration supply. I imagine Roy Nascewicz has them too.
pat in Santa Cruz is offline   Reply With Quote
