Anyone know anything about these plugs. There are some adverstised here on NZ Trade Me (see link). I think they are English, I did a web search on the company. Maybe our "Pommy" resident v8 guru Mart can help?
http://www.trademe.co.nz/motors/car-...-845119805.htm Thanks GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
Don't know anything about those plugs (except that they must be solid platinum $$)
Have used similar E3 plugs that make the same claims and you would be hard pressed to find any measurable difference compared to a standard plug. http://auto.e3sparkplugs.com/
No experience as such, however, electrical law dictates the spark will take path of least resistance; it will not magically split to all three grounding electrodes, so, in this case, having three ground terminals is just a gimmick.
#4 | |
![]() Quote:
"Spark will always jump to the cooler of the three surfaces etc"" ![]() |
"Came too close to dying to stop living now!" |
yes thats the theory.......
They had those type of plugs in the early 50s. I had a set. Don't remember if it made a difference.
The precious metal spark plugs need a modern high voltage (read that = enough current to weld with) ignition system to stay clean. They often don't work well and foul quickly with older low voltage / low current ignition systems like those in our pre WWII cars.
I would not spend that kind of money on a spark plug.
1910 Touring 1914 Touring 1915 Touring 1917 Torpedo Runabout |
if they are anything like the split fire plugs,the splitfires must have split the fire every where but where it needed to be,I tried two sets in different applications,
sorriest plug I ever used, tossed them in the trash and went back to motorcraft/ AUTOLITE, jmo. Fordestes |
i would like to try those, not much more $ than regular plugs, i had twin prong plugs that would alternate which prong it jumped to every spark pulse or 2 when they were set right. Even if only because it looked cool.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
