I have 3 connecting rods plasti-gaged to .001 and connected. I can barely turn the crankshaft! Is that normal?
Not much info.
What about the 4th ? And how about the mains ? Have you tried loosening all the caps slightly on all the rods and mains and see what that does ? What has recently been done ? New rings maybe ? Has this monster been sitting for a long time ? |
engine ran ok when I got it.---low compression 45 psi. eng sat for 40 years. no ridge in cyls---finish hone- new pistons and rings. did not touch mains. Is this normal ? may have to pull to start
Disconnect or merely loosen all caps, tighten one main at a time and rotate after each, continue on with rods until you find out where the drag is. If you find a tight journal, loosen and continue in case more than one is tight.
And of course it is possible that drag is upstairs and coming from ring or piston misfit. |
Well tight is normal after a rebuild but clearance of only .001 ? Are not the shims at least .005?
#6 | |
Herm. |
Many times on an engine that has some use the rod journals may not be round anymore. This condition will give a false reading with plastigage. You may actually be tighter during part of the crank revolution. The same is true of the mains but I have not seen as much of a difference in main journal roundness as I have at the rod journals. Something to consider or check if you have not placed a micrometer on the journals. Solution...loosen them a bit.
Good Day! Last edited by Dave in MN; 04-08-2015 at 10:58 AM. |
Are you turning over with the starter or by hand? I recently helped someone who had worked on his engine and trying to start, it would just barely turn. What I found was his timing was off and firing too soon. Cranking with the ignition off spun really well. We retimed and all OK.
Thanks for all the good advice. I think .001 is to tight and the journals are not round. I will go for .001-75 and should free up---will let you all know----
What torque setting are you using on the nuts?
http://www.abarnyard.com/ |
#11 | |
![]() Quote:
Why not go with what Herm said, i.e.- .0015 ? That IS what Ford set them at , if I remember correctly. All good thoughts given here , and the info that you gave about NO ridge ring says a lot also. The mains may have been set just right and I would not disturb those , until you find that all else is OK ! I'm wondering...did you put NEW rope seals in block and pan ? If so, you will get a lot of resistance after either or both of these are installed..which , IMO, you can understand will happen. Or is your hard turning without these seals ? For an example, I just put a short block together ....mains/rods at .0015. ALL turned well, until I installed new rope seals at front of crank...wow, what resistance then !! Here is a 'tip' that I got from a race engine builder. after EVERY step of assembly , turn engine over by hand twice to see what if any problem exists. Works for me.. Last edited by hardtimes; 04-08-2015 at 12:43 PM. Reason: .......... |
Educate me! What is .001-75?
#13 | |
![]() Quote:
This an engine which had acquired the classic "whuppa-whuppa" sound when idling. And rods about 3 thou egg shaped. I guess I used the engine until it seemed like the whuppa whuppa was just a little too much. Traveling down the Mid-Cape Highway at 55 plus (3.54 rear) suddingly the whuppa-whuppa grew EXTREME. A step change in audibility. Not thrown a rod but alarming in it's contemplation. I nursed it home not exceeding 35. A tear down revealed that I had lost one of the rod nuts and the rod cap was being held by only one side. "Engiine done" I thought to myself. I found the missing nut - AND the pieces of the cotter pin - in the bottom of the oil pan - of course. Joe K
Shudda kept the horse. |
#14 |
Closer to 0.002 than 0.001.
(heh - 0.0175) Joe K
#15 |
#16 |
![]() 0.0175 would be 17 and one half thousandth. or a little over 1/64 .00175= 1 and 3/4 thousandths. Which is what Herm said. The rule of thumb is .001 clearnce per inch. crank dia. crank is 1=1/2 so that would be .0015 min like Herm said. Last edited by George Miller; 04-08-2015 at 01:44 PM. |
#17 |
I was told this is a "Sears" engine!!! it was red!! I reshimmed #2 and got close to a .002 with the plasti ( at the bottom of the stroke)--tightened to 42 ft lbs---to tight!! All others loose.. AT WHAT CRANK POSITION SHOULD I ADJUST TO GET A TURNABLE CRANK?
