Old 08-23-2014, 11:30 AM   #1
jhaas63
Default Which spark plugs for a 53 flathead?
My F100 is due for a tune up and I am wondering which is the popular choice for my 53 flathead? It is a stock motor. Thanks.
jhaas63 is offline   Reply With Quote
Old 08-23-2014, 11:45 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Which spark plugs for a 53 flathead?
The search box is your friend. Just type in "Spark Plugs"
https://www.fordbarn.com/forum/showth...ad+spark+plugs and
Old 08-23-2014, 01:48 PM   #3
supereal
supereal's Avatar
I use Champion RJ14YC.
supereal is offline   Reply With Quote
Old 08-23-2014, 07:57 PM   #4
oldsman41
my local napa still carries the champion h 10 use those in my 51
oldsman41 is offline   Reply With Quote
Old 08-24-2014, 11:51 AM   #5
51504bat
51504bat's Avatar
I'm running Champion H-10's in my 8ba and the local parts house had them individually for lawn mowers. So if you want to run H-10's and you can't get them at your local parts house try a lawn mower shop. H-10's are what my 57 Motors Manual calls for my 8ba.
Old 01-14-2015, 12:31 AM   #6
camswax
Hi all I also run champions in my flathead but iam surprised on how many people advise me to toss the out and use NGK any one else been told this?
camswax is offline   Reply With Quote
Old 01-14-2015, 06:36 AM   #7
SofaKing
SofaKing's Avatar
Since lawnmowers were brought up, I have had trouble with Champion plugs fouling in both cars and Harleys when other plugs like AC, NGK and Bosch all worked great.
SofaKing is offline   Reply With Quote
Old 01-14-2015, 06:40 AM   #8
Vic Piano
Vic Piano's Avatar
I run Autolite 216's in all our Flatheads. I wouldn't put Champion plugs in anything except the garbage can... But, that's just me...
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 01-14-2015, 09:10 AM   #9
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
+2 on the Autolite, 216 I use them on all my stock head flatheads. Walt
Old 01-14-2015, 09:30 AM   #10
Mike51Merc
Mike51Merc's Avatar
Ngk b6l
Mike51Merc is offline   Reply With Quote
Old 01-14-2015, 10:51 AM   #11
Fordestes
I have had nothig but problems from champion ,even when I worked for chrysler in the 70s it seems they really caused problems in the winter months especially,
I always try to use autolite in everything I can find them for and the ngks are my second choice, i tried nippondenso in my ford engines both early and late and had one instace where a ford 300 six just flat out quit left me stranded, never befor seen a set of plugs just give up and stall out an engine,it was across the street fro a parts store and all they had were 3 ngks in stock to fit my egine so I installed the three and managed to get it running enough to get it home and replaced the other 3 plugs and never had anymore problems.
Fordestes,
Fordestes is offline   Reply With Quote
Old 01-14-2015, 01:46 PM   #12
my4dv8
Seem to still be the same story of ABC. Anything but champion.. We run NGK B6L .
my4dv8 is offline   Reply With Quote
Old 01-14-2015, 07:14 PM   #13
TStiles
the 216's are a good plug
TStiles is offline   Reply With Quote
