Old 12-19-2014, 05:54 PM   #1
Tom Smith
Default Shoe Arching Fixture
Just purchased a Ammco Shoe Grinder. Would like to make the holding fixture plates that I have seen pictures of. Anyone with a sketch or information they are willing to pass on.
Tom Smith is offline   Reply With Quote
Old 12-19-2014, 07:26 PM   #2
d.j. moordigian
d.j. moordigian's Avatar
Default Re: Shoe Arching Fixture
You'll get the idea from the photos,....Ammco made 3 types of machines,
which model number do you have?
....................AMMCO 880 Brake Shoe Grinder Question..............
d.j. moordigian is offline   Reply With Quote
Old 12-19-2014, 08:48 PM   #3
Tom Smith
I purchased the 8000 model
Old 12-21-2014, 05:29 PM   #4
Tom Smith
ttt
Old 12-22-2014, 10:33 AM   #5
d.j. moordigian
I looked up your model 8000 in the manual,...it has a different clamping system
than the 880. I suspect they should be close.
My plates measure,....1/8" X 1.75" X 7.25". The pins are 5/16" X 5/8".
Does this help?
Old 12-22-2014, 09:12 PM   #6
Tom Smith
Thank you dj for your reply. On your 880 do you have a consistent way of mounting the plates to your machine? Should I consider adding the holes to match the lower clamp pins?
Old 12-23-2014, 11:52 AM   #7
d.j. moordigian
Okay,....I see where your going.
Yes, with the plates, it's consistent.
In the Ammco manual,..it states too center the shoe in the clamp.
I couldn't do that because the "pins" were right on the edge of
the holes,...it wasn't giving even clamping on the shoe. See the
photo with the black dots. That's why I made the plates.
Post, if you can, a photo(s) of your clamp / shoe set-up if your
having problems.
Dudley
