Old 09-15-2014, 07:38 AM   #1
marty in Ohio
marty in Ohio's Avatar
Default Model T gas tank?
I'm an "A" guy but yesterday at a car show I met a "T" guy who was showing a 1926 or '27. Being unfamiliar with the "T" I looked it over pretty good. I noticed that the coil boxes were under the hood and started looking further. I saw that the gas tank was in the cowl on the right side behind the dash board. I asked the owner how the tank was filled and he opened, what I thought, was a vent on top of the cowl and there was a gas cap. Was this original or was this a modification? I thought all Model T's had their tanks under the seat. Somebody please set me straight.
Marty in Ohio
marty in Ohio is offline   Reply With Quote
Old 09-15-2014, 07:41 AM   #2
jackdaron
Default Re: Model T gas tank?
Sounds original to me
jackdaron is offline   Reply With Quote
Old 09-15-2014, 08:39 AM   #3
Buckelew
Buckelew's Avatar
Prior to '26, Model T gas tanks were under the front seat unless modified to otherwise.
In '26 and '27, the gas tank was typically in the cowl.
Buckelew is offline   Reply With Quote
Old 09-15-2014, 11:35 AM   #4
redmodelt
redmodelt's Avatar
Except for the one ton truck (TT) and fordor 26 and 27 tanks were under the cowl.
Old 09-15-2014, 03:38 PM   #5
marty in Ohio
Thanks guys. I learned something today.
Marty
Old 09-15-2014, 09:03 PM   #6
Layden B
Just for general info, 1911 and 1912 Torpedos have the gas tank on the back deck.
Am being a nit picker!
Layden B is offline   Reply With Quote
Old 09-16-2014, 08:05 AM   #7
marty in Ohio
Layden,
Nit picking is good. All nits should be picked! I didn't know that any Model T's had the tank that far back. At that distance, was it still gravity flow?
Marty
Old 09-16-2014, 10:15 AM   #8
Buckelew
Buckelew's Avatar
My racer's is on the back deck, and it's still gravity flow. Before I put it on the road will probably raise the tank a bit. No doubt some of the grades around here are steeper than the angle from the tank bottom to the B carb.
Old 09-16-2014, 10:50 AM   #9
Layden B
Marty,
Yes still gravity flow. It is mounted higher as it is above the body deck rather than being mounted to the frame.
Old 09-19-2014, 09:44 AM   #10
Willie in Houston
Willie in Houston's Avatar
There were some coupe cars with a square tank in the trunk just behind the seat.
Willie in Houston is offline   Reply With Quote
Old 11-06-2014, 09:13 PM   #11
C26Pinelake
This is my opinion also.
Wayne
C26Pinelake is offline   Reply With Quote
Old 11-07-2014, 12:47 AM   #12
Steve Jelf
Steve Jelf's Avatar
When you go shopping for tanks, you find that the 26-27 one is usually expensive. Because of the complex shape, it's not being reproduced.
Steve Jelf is offline   Reply With Quote
Old 11-07-2014, 10:42 AM   #13
stevests
stevests's Avatar
I don't believe it's the shape complexity as much as it is the "overflow" tube running through the tank that makes it a difficult proposition to manufacture economically.
stevests is offline   Reply With Quote
