I have two nice original 1930 - '31 radiators, but both have a leaking tube in the front row of their cores. Repairs were attempted on both radiators, so the fins in front have been cut away in a 1" diameter area.
Has anyone made a repair of original fins by snipping some off of one radiator to restore another?
Bob Bidonde |
Could the top tank be taken off to expose the tubes then replace the missing fins?
weighing the expense against a recore by Berg? I guess the spot is wrong for covering with a national club radiator badge? I have seen some radiator repair work done by a now retired local area radiator guy and there is no substitute for experience. |
My 30-31 radiator had rock damage that took out the fins on a one inch area of the middle of the front of the radiator. It also caused a leak that was repaired on the road by pinching off the tube. I cleared away the smashed fins and McGyvered in some fin sections cannibalized from a junked radiator. The fins were sealed in place with some carefully placed J-B weld and given a touch of paint. Now it is hard to spot the repair. My wife questioned why I saved that junk radiator.
Ursus,
I am thinking about doing the same thing. Recently I did some repair work on the fins of a repro radiator, and I found that POR-15 Chassis Black epoxy paint is an excellent way to bond new fins into place.
Bob Bidonde |
