Old 10-23-2014, 12:40 PM   #1
SETHDOUG
Default Brke n shake ????????
HI GUYS ,,, I HAVE AN ORIGINAL UNRESTORED 31 TUDOR SEDAN ,,,
BARN FOUND AFTER 26 YEARS ... AFTER MUCH WORK ITS REGESTERED AND DRIVES GREAT ... WELL ALMOST GREAT ,,,,,COMMING TO A STOP PRESS THE BRAKS I GET A HORRIFFIC SHAKE IN THE CAR ,,,IS THIS BRAKES >>>>OR IN THE STEERING,,, SCARES ME TO DEATH ,,,,Where do i start ,???,,thanks Seth Carley ,,trumbull ct [email protected]
SETHDOUG is offline   Reply With Quote
Old 10-23-2014, 12:46 PM   #2
700rpm
700rpm's Avatar
Default Re: Brke n shake ????????
Something's loose or worn out in your steering geometry. The are lots of causes. If you do a search here for "shimmy" you'll find the potential causes and fixes.
Ray Horton, Portland, OR
Old 10-23-2014, 02:10 PM   #3
Patrick L.
Patrick L.'s Avatar
Seems like you're really concerned about this since you're yelling for help.
It seems to me like you have more of a problem than just a warped brake drum or two.
I agree with looking over the suspension and steering really good. Appears as though there is a thing or two or three that is loose. Start with the wheel bearings and work your way back to the steering box.
Old 10-23-2014, 02:49 PM   #4
Gary Gregory
Gary Gregory's Avatar
King pins and bushings
Gary Gregory is offline   Reply With Quote
Old 10-23-2014, 04:11 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Have you pulled the front drums to look for rust spots inside the drums? This can cause a pulse or shake when braking. My newer car will rust on the disks after a few days and pulse for a block or two until applying the brakes lightly will wear the rust off.
Old 10-23-2014, 04:25 PM   #6
afuncar
My shudder an shake was caused by a loose nut on the front spring perch.
afuncar is offline   Reply With Quote
Old 10-23-2014, 05:36 PM   #7
Larry Seemann
Like afuncar said I had that happen once - loose not on the spring perch. Acted just like you describe.
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 10-23-2014, 06:07 PM   #8
1931 flamingo
1931 flamingo's Avatar
Ck the brake backing plates for tightness to the spindles.
Paul in CT
Old 10-23-2014, 06:56 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Flat spots on the tires from sleeping 26 years??
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-23-2014, 07:29 PM   #10
Duffy1
I have seen loose radius rods cause this. Replace radius ball or put in washer over existing ball . Vendors have the washer.
Duffy1 is offline   Reply With Quote
Old 10-23-2014, 08:03 PM   #11
afuncar
My shutter was the nut under axle for spring perch .
Old 10-24-2014, 05:30 AM   #12
Ed Saniewski
Ed Saniewski's Avatar
I am with Duffy, check the radius rod ball first. make sure the springs are in the right place and the nuts are tight. This is an easy thing to check, and if loose will give you a lot of shaking. Ed Saniewski
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
https://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 10-24-2014, 06:16 AM   #13
Tom Wesenberg
When I bought my 29 Tudor it also had a bad shake while braking. The right rear wheel had a flat spot probably from loosing a wheel while driving. I replaced the drum and backing plate, and it brakes smoothly now. I've seen quite a few drums with flat spots. Hard to believe that many people lost wheels while driving.
