Old 09-30-2014, 06:00 AM   #1
old46ford
Default Exhaust Source - Recommendations
Any recommendations for a good quality (Made in the USA) source for a replacement exhaust pipes (minus muffler)? I have a 1946 coupe.
Much appreciated.
old46ford is offline   Reply With Quote
Old 09-30-2014, 07:58 AM   #2
donald1950
Default Re: Exhaust Source - Recommendations
i found this vendor for my 53. have not purchased yet but talked to them and they seemed quite nice.... http://waldronexhaust.com/cart/
donald1950 is offline   Reply With Quote
Old 09-30-2014, 08:20 AM   #3
gmc1941
gmc1941's Avatar
Waldron has some nice dual set ups and a nice guy to talk to.
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 09-30-2014, 08:25 AM   #4
old46ford
Thanks guys!
Old 09-30-2014, 01:56 PM   #5
1963turnerjohn
1963turnerjohn's Avatar
Waldron is a good source - I purchased dual setups and seperate pipes from them and all worked well.
Let us know how you make out
John
1963turnerjohn is offline   Reply With Quote
Old 09-30-2014, 02:16 PM   #6
wisbangman
wisbangman's Avatar
I have a 1985 toyota celica GTS convertible, that I bought in 1993. I haven't done any thing to that exaust system, since I bought it 21 years ago ! My guess is that it is a stainless system. I just put a stainless system, complete, on my 1967 cutlass that I have owned since 1989 - 25 years. Hopefully, no more replaceing exaust on that one! On my 39 Standard in my avatar, I did replace the tail pipe recently, with regular steel stuff, but if I needed a complete new system, I would be looking into stainless, just saying.
wisbangman is offline   Reply With Quote
Old 09-30-2014, 02:51 PM   #7
oldford2
oldford2's Avatar
Exhaust or tail pipes or both. I find the best way is to find a good muffler shop that has an expert pipe bender and let him build your system. And more reasonable and trouble free. Mail order parts seem to always need "fitting". You did not say if you had headers or stock manifolds. If original manifolds remove the crossover pipe and block off the passenger side entry port. The drivers side can come off the front of the manifold and down around the steering box clearing the dip stick tube. Then thru the hole in the frame and head back. Be sure to depress the clutch pedal when installing to insure no interference. also insulate the gas and brake lines where they come close to the pipe. That's how I did it to install a dual exhaust system.
John
John
oldford2 is offline   Reply With Quote
Old 09-30-2014, 06:31 PM   #8
supereal
supereal's Avatar
At our shop, we stopped doing exhaust replacement years ago because we have an excellent local place that makes up systems from stock material. They know how to set up pipes so thermal expansion doesn't cause rattles, and the cost is not more than mail order.
supereal is offline   Reply With Quote
Old 09-30-2014, 07:02 PM   #9
Bertha
Bertha's Avatar
I went with a local shop, with a good reputation, that I've dealt with before. Custom made for our 53 Victoria
Their out there, support them.
Bob
..."they are only original once"
Bertha is offline   Reply With Quote
