Old 09-17-2014, 07:35 AM   #1
flashback
Default Alignment shop Raleigh NC
Does anyone know of a good alignment shop in the Raleigh NC area. I have a 1950 F-1 Ford truck.
Thanks for any help.
flashback is offline   Reply With Quote
Old 09-17-2014, 06:05 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Alignment shop Raleigh NC
I'd probably look for an established (old) spring shop or truck repair facility.
Paul in CT
Old 09-18-2014, 06:38 PM   #3
tanner
tanner's Avatar
What is the suspected alignment problem? You can easily set toe-in and change caster if truck wanders by adding shims under front axle. Camber is a different animal.
tanner is offline   Reply With Quote
Old 09-18-2014, 09:44 PM   #4
csmbraz
Supreme Auto, 410 W. South St....919-834-1257 ...downtown near the Civic center....been in Raleigh since 1957....currently has a customer's 1956 GMC in the shop for steering gearbox repair...
csmbraz is offline   Reply With Quote
Old 09-19-2014, 10:35 AM   #5
flashback
Thanks for the replies. I have replaced my bias ply tires with radials.
The info I have been able to find is that the camber needs to be adjusted.
