Old 08-20-2014, 06:18 AM   #1
oldskool
oldskool's Avatar
Default flipperbar hubcaps banjo rear
anyone running 15" full size flipper hubcaps on a banjo rear im thinking or running a set on my 46 merc and wonder if they clear axel..thanks oldskool
oldskool is offline   Reply With Quote
Old 08-20-2014, 07:29 AM   #2
MuskegonFlatheadFan
MuskegonFlatheadFan's Avatar
Default Re: flipperbar hubcaps banjo rear
I have two different pair of them, one fit, the other didn't. They were too shallow. They were both newer repos. If possible, try before you buy.
MuskegonFlatheadFan is offline   Reply With Quote
Old 08-20-2014, 07:33 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
And if they are going to be covered by skirts and the axles don't clear think about doing what we did back then and what I've seen done today, cut clearance holes in the covers.
Old 08-20-2014, 07:44 AM   #4
Vic Piano
Vic Piano's Avatar
This won't answer your question but, with the cars I have skirts on, I just run trim rings (Beauty rings) on the rear wheels.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 08-20-2014, 08:05 AM   #5
Pat/Ohio
Pat/Ohio's Avatar
Although I don't have a banjo rearend...I am running these same repro caps on my '50 with skirts. I have about a 1/2 inch to spare. Pat
Pat/Ohio is offline   Reply With Quote
