Old 08-17-2014, 08:52 AM   #1
russcc
Default 8BA Dwell
Stock 8RT. The books says 58-63 degrees of dwell. I am getting about 48 degrees at idle with about a .015 to .016 point gap. Initial timing with the vac plugged is set with the pointer on the raised dot on the crankshaft pulley, What's up ? Dwell/Tach is an old timer. Thank you.
Old 08-17-2014, 09:35 AM   #2
V8 Bob
V8 Bob's Avatar
Default Re: 8BA Dwell
If you re-read the book, that '48-'53 8BA spec is in percent, not degrees. 58-63 percent of 45 degrees (1/8th of 360 distributor rotation) equals 26.1-28.3 degrees, or 27 target degrees dwell, the spec most single point Ford V8s used up through the early '70s. FYI, the raised dot on the 8BA crank pulley is 2 degrees BTDC.
Old 08-17-2014, 11:59 AM   #3
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Originally Posted by v8 bob View Post
if you re-read the book, that 8ba spec is in percent, not degrees. 58-63 percent of 45 degrees (1/8th of 360 distributor rotation) equals 26.1-28.3 degrees, or 27 target degrees dwell, the spec most single point ford v8s used up through the early '70s. Fyi, the raised dot on the 8ba crank pulley is 2 degrees btdc.
yep CORRECT........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 08-17-2014, 12:14 PM   #4
tubman
tubman's Avatar
Bubba,
Notice he said "stock 8RT". Your answer might be a little misleading.
Old 08-17-2014, 08:16 PM   #5
BUBBAS IGNITION
Originally Posted by tubman View Post
Bubba,
tHANKS I WAS THINKING DUAL POINTS , I FIXED IT....
[email protected]
