Got a '36 with 12V negative ground system. Replaced original light switch with modern push/pull switch, problem is only with left rear tail light; with lights on and stepping on brake pedal tail light goes out, with lights off and step on brake pedal brake light works. Any ideas?
Make a good ground for the light sockets.
Bruce
Works good Lasts long time |
Probably a grounding problem or "sneak circuit" with that left taillight socket. DD
36tudor, did you get the engine straightened out? Please tell those of us that followed that thread what you did to fix it.
https://www.fordbarn.com/forum/showthread.php?t=141256 |
Couple of things I didn't mention, the brake light circuit is fused and I only show 3.5V at the contacts with bulb removed in the the light bulb socket, but filament is very bright when bulb is in? I ran separate grounds for the sockets but the on on drivers side may be faulty & will check tomorrow.
UPDATE: Right now getting 12+Vs at contacts in light socket, have good second ground but light is dim and with head lights on and step on brake pedal tail light on left side goes completely out, tail light on right is bright and works perfectly. Only one filament on the left tail light comes on. Last edited by 36tudordeluxe; 08-14-2014 at 07:16 PM. |
#6 | |
Problem solved, it was a bad ground as suggested earlier, established new grounding source and everything works as it should.
