Old 08-12-2014, 04:49 PM   #1
19Fordy
19Fordy's Avatar
Default 1/4-27NPT plastic threaded pipe plug.
I meant to say 1/8-27 NPT not 1/4.
I would like to install a drain plug on my polypropylene gas tank and am wondering where I can buy a 1/8-27NPT plastic plug. Anyone know of a source? I don't want to buy a bag of them - just one or two. Thanks.
Old 08-12-2014, 04:53 PM   #2
Mike B
Default Re: 1/4-27NPT plastic threaded pipe plug.
I think 1/8th inch is 27 TPI...1/4 is 18? as I recall.
Check your local HW/Home depot?
Mike B is offline   Reply With Quote
Old 08-12-2014, 05:01 PM   #3
19Fordy
19Fordy's Avatar
Home Depot doesn't sell small plastic ones with 1/8-27 NPT threads. I need either nylon or polypropylene.
Old 08-12-2014, 05:25 PM   #4
Ronnie
Ronnie's Avatar
Go to a place that does underground sprinkler installations.
R
Ronnie is offline   Reply With Quote
Old 08-12-2014, 06:42 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Does it really have to be plastic?
The option that I would consider is a stainless steel Allen plug (less sticking out to get knocked off )
Such as this from Grainger---
http://www.grainger.com/product/Hex-...AS01?$smthumb$
Old 08-12-2014, 07:07 PM   #6
PeteVS
PeteVS's Avatar
McMaster Carr has an assortment...
http://www.mcmaster.com/#standard-pl...-plugs/=t95b2t
Old 08-12-2014, 07:07 PM   #7
mrtexas
mrtexas's Avatar
How about aluminum? There is always ebay. Not too many items not on ebay. Summit Racing also has them.
http://www.ebay.com/itm/Fragola-4932...dd8665&vxp=mtr
mrtexas is offline   Reply With Quote
Old 08-13-2014, 10:11 AM   #8
19Fordy
19Fordy's Avatar
Thanks guys. I ordered a few from McMasterCarr.
Old 08-13-2014, 10:32 AM   #9
MuskegonFlatheadFan
MuskegonFlatheadFan's Avatar
Always remember Fastenal, they are everywhere
http://www.fastenal.com/web/products...VendingMachine=
MuskegonFlatheadFan is offline   Reply With Quote
Old 08-13-2014, 10:37 AM   #10
40cpe
40cpe's Avatar
Originally Posted by 19Fordy View Post
[B]
I would like to install a drain plug on my polypropylene gas tank. Thanks.
How are you going to get the threads in the tank body?
Old 08-13-2014, 11:40 AM   #11
19Fordy
19Fordy's Avatar
Gosh, I went to the Fastenal website earlier and couldn't find them.
Old 08-13-2014, 11:43 AM   #12
19Fordy
19Fordy's Avatar
I will drill and tap a 1/8-27NPT hole in the bottom of the tank. Already tried it on a practice piece of polyethylene plastic and it worked fine with no leaks. The trick is not to tap too deeply with the tap, otherwise you loose the taper.
Old 08-13-2014, 03:16 PM   #13
40cpe
40cpe's Avatar
Is this a Tanks tank?
Let us know how it works out.
Old 08-13-2014, 04:31 PM   #14
Tony, NY
I bought a Tanks Inc universal tank for my project and never realized that it used an in-tank fuel pump. The pickup came out the top of the tank. Had to have a bung soldiered to the bottom. They should put drain plugs in their tanks.
Tony, NY is offline   Reply With Quote
Old 08-13-2014, 05:49 PM   #15
19Fordy
19Fordy's Avatar
OK, I will. The tank is a polyethylene tank from TANKS.
