Old 07-15-2014, 04:08 PM   #1
ericr
ericr's Avatar
Default "raven" finish equals rust finish
this is prompted by a recent post wherein it is mentioned that the horn flange bolts were originally raven finish.
every single raven finish item I ever bought is now covered with a protective layer of rust....
ericr is offline   Reply With Quote
Old 07-15-2014, 04:23 PM   #2
peters180a/170b
peters180a/170b's Avatar
Default Re: "raven" finish equals rust finish
it all depends on the person or company that does the plating. I used Danbury Plating in Conn. ,,They do industrial plating /finish. The key is when using original BOLTS and NUTS ["NOT" LOCK WASHERS] is to prep the parts first. i first start to soak them in gas and degrease them, then I wire brush them, put them into metal prep for a few hours and then wire brush them again until the gold [rust] finish is gone. I wire brush the lock washers only..... and then off to Danbury Metal finishers. Google it on your computer and look for a plater near you.I top them off with Astro dope.[a good hobby shop sells it]My bolts are going on 7 years +.
peters180a/170b is offline   Reply With Quote
Old 07-15-2014, 06:14 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
That's why they don't rust the dope seals the finish.
Old 07-15-2014, 06:18 PM   #4
Midwest Tin
Midwest Tin's Avatar
Hi,
Are there any do it your self raven plating kits available. Also has anyone tried the kit? Jim
Midwest Tin is online now   Reply With Quote
Old 07-15-2014, 06:28 PM   #5
Mike V. Florida
Originally Posted by Midwest Tin View Post
Hi,
https://www.fordbarn.com/forum/showthread.php?t=43054
Old 07-15-2014, 06:48 PM   #6
wrndln
Jim,
I purchase a quart of Parkerizing concentrated solution on eBay a couple years ago. I did two or three batches. I was disappointed in that some of the Parkerized bolts and nuts rusted after not too long of time. The material is manganese phosphate I think. The link below is the stuff I bought and used.
Rusty Nelson
http://www.ebay.com/itm/Parkerizing-...0cb3c9&vxp=mtr
wrndln is online now   Reply With Quote
Old 07-15-2014, 07:21 PM   #7
Roadster62
Roadster62's Avatar
I've got a box of original from the 1930's horn bolts, they still look as good as when they were first plated. I've often wondered what type of bidding war "Fine Point" people would get into on "That Auction Site" if I listed one horns worth? Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 07-15-2014, 08:07 PM   #8
Willie Krash
Willie Krash's Avatar
This has been discussed before. As an antique phonograph collector we simulate that finish by dropping red hat bolts in dirty, very dirty crankcase oil.
https://www.fordbarn.com/forum/showthread.php?t=19833
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 07-15-2014, 08:12 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
My stuff ain't for national judging, semi gloss black works for me.
Old 07-15-2014, 08:25 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
I like G-96 gun blueing, then rub it with ATF. Did my gun a year ago and still looks the same as the day I blued it. I've also done a few small car parts. Even with a clear coat, I'd rub the part with an oily rag to help keep rust away.
Don't waste your money on Birchwood Casey blueing.
Old 07-16-2014, 03:19 AM   #11
dave in australia
Tom beat me to it. After the parts are blackened/blued, they need to be heated and then placed in oil/ATF. Not heated to anywhere near red, but about 100C/212F is enough. This will open the pores slightly and allow the oil in. When I was an electroplater, we would heat blackened parts up to around that temp in the oil, so the oil was at the same temp.
dave in australia is offline   Reply With Quote
